Results 1 to 11 of 11
Thread: Halos
    ColeMonkey's Avatar
    ColeMonkey is offline Stewed, Screwed, & Tattooed!
    Jun 2006
    Under your bed
    Halos
    I was just wondering if anyone has had any problems with them? Like staying on? I'm not sure how they are attached, glue or what?
    The reason I ask is cuz on my Cougar I had, I had Halos and they kept breaking off! The guys on the Cougar forum said to use the wire from the twisty ties, but those kept breaking on others Cougars so they said to use epoxy glue. So I did! And it worked very good till... the glue turned yellow and then cracked, letting the halos loose and bouncing around in my headlight!
    So any info would be appreciated for when I get my Magnum and install these. Thanx guys & gals!
    lowriderman3's Avatar
    lowriderman3 is online now Rut Ro!
    Low Down Dirty South!
    They are glued on. Never had that type of problem with mine on this car or my last.
    ColeMonkey's Avatar
    Jun 2006
    Under your bed
    What kind of glue did you use???
    Quote Originally Posted by ColeMonkey View Post
    Someone else might be able to chime in. I had AAC mod mine so they already came installed.
    ColeMonkey's Avatar
    Jun 2006
    Under your bed
    MR. J's Avatar
    MR. J is offline Are you down with the wicked clown?
    Oct 2005
    Palm Springs, CA
    Epoxy is what AAC recommends to use for their DIY kits so I would assume epoxy is what they use in their pre-built headlights.
    HemiLover's Avatar
    HemiLover is offline LX Guru
    Sacramento, CA
    Epoxy....that 2 part mix stuff thats clear. Just a drop in a couple spots on the rear of the halo ring and at the rubber wire boots that go thru the bezel.
    Click the sig for mods and pics....
    ColeMonkey's Avatar
    Jun 2006
    Under your bed
    Hmmm, cuz I had a bad experience with that...
    rsmeanie is offline Internet friends are the best.
    May 2006
    No. Calif.
    I had AAC install mine and I think they used epoxy. If you look cafefully, you can see a couple of small blobs on each ring. No problems whatsoever.
    • 2006 300 SRT/8 - Bright Silver
    • BT Frankentake CAI, Zoomers exhaust, AAC ColorShift v2.0 halos, CDC Glassback roof and trunk panel, HID fogs, Stealth markers and bulbs, LED tails and mirror covers, 22elite cover, TommyZ Deep Dish grill, USW 22" Extravagants with Vredestein tires.
    ColeMonkey's Avatar
    Jun 2006
    Under your bed
    I'll probly have them just do mine then.
    dgreekman's Avatar
    dgreekman is offline LX Newbie
    No problems here....even on the newly installed tail halos
    K-1 Technologies 426 Stroker kit, Custom Wiseco inverted dome pistons, port & polished heads and intake, custom grind Comp 426 cam, Polished T-Trim Vortech supercharger, Kooks Longtube headers with flowmaster exhaust, CPR Fuel rails, Walbro 255 fuel pump, MSD Ignition, ARP mains and studs, ATI Balancer, DSS 1000 HP ½ Shafts, LSD, custom Vaca Performance Tune, KW coilovers, Hotkich sway bars, Asanti 3-piece AF-403, polished and anodized engine bay, RK Sport Heritage wing, Alpine and JL audio system, AAC Oracle Demon Eye headlights, tails, and HID Conversion
    www.projectsrt.com
