Results 1 to 15 of 27
Thread: Fuel pump?
    V8Mag's Avatar
    V8Mag is offline Danger,Death,Destruction
    Sep 2008
    Fort Campbell/Clarksville, TN
    Fuel pump?
    Both my fuel pumps have went out and was wondering anyone knows of a drivers side fuel pump for sale or where i can pick one up. Would an aftermarket one work for this being i have a brand new passenger side pump. I purchased a passenger side one today but no one has a drivers side one. Any info will help of greatly
    Posted via LXFMobile
    SRT8U's Avatar
    SRT8U is offline www.speedlogix.net
    Jun 2006
    South Florida
    I think we have one here, I will check and let you know.
    Curious though...what if any mods you have/how many miles on your car? Wondering what caused the failure.
    Kris | Mopar Specialist | Speedlogix, Inc.
    2006 Charger SRT8 Vortech Supercharged by SpeedLogix
    *** We Price Match - click here to see how it works! ***
    Speedlogix, formerly named BMC Performance ... same people, new name!
    Visit us online at Speedlogix.net or call 888-SPD-LOGX to talk to one of our Mopar experts!
    V8Mag's Avatar
    Sep 2008
    i have 90036 miles on the car and have jba mide pipes and cat-back exhaust everything else is cosmetics. Which fuel pump is active when the tank is half and below because once i got to half a tank it acted up and before i hit half tank it was fine. I'm just curious because if i replace one id rather replace both being im right there but id be nice to know for further info
    fnkychkn's Avatar
    greasy cardboard box
    there is only one electric fuel pump. it's on the left side. the right side houses a venturi pump whose sole purpose is to transfer fuel from the right side to the left side. if you're running out of fuel below half tank, the venturi pump is not working properly. if you have EVIC, you should be able to see how much fuel is in either side of the tank. if the left side is very low or empty and the right side shows fuel, then your venturi pump is not working properly. this could be caused by the pressure regulator or a dislodged hose in the tank. it it runs fine above 1/2 tank, there's no need to replace the electric pump.
    form FSM:
    The way the pump works is as follows, fuel enters the reservoir of the driver side module. The fuel pump pumps the fuel through the filter to the passenger side module through a supply line inside tank. The pressure regulator inside the passenger side module regulates the pressure at 58 psi. All unused fuel that is not sent to the engine is fed through a venturi at the bottom of the passenger side module. This creates a low pressure siphoning effect and draws fuel from the passenger side of the tank and transfers it to the drivers side tank via siphon hose inside the tank. While the vehicle is running the fuel in the passenger side of tank is continuously transferred to the drivers side. Fuel will continue to fill the drivers side tank till it reaches the bridge section and then start to spill over to the passenger side.
    V8Mag's Avatar
    Sep 2008
    Here is what my car reads
    TNMM
    Magnum Sold
    CURRENT PROJECT: Getting Financially Stable Again
    MuscleMan305's Avatar
    MuscleMan305 is offline Hopped up on Super Supreme
    South Florida
    So what does it mean if my LT is always alot higher than my RT on the EVIC? I'm a little worried because my car has died on me several times before the gas guage warning light turns on. Is LT left tank looking at it from the front to back, in other words LT=passenger side?
    USCG Charger's Avatar
    USCG Charger is offline Inertia 383 Stroked
    Jan 2007
    V8Mag's Avatar
    Sep 2008
    Wish I would have saw that before I ordered the other one
    TNMM
    Magnum Sold
    V8Mag's Avatar
    Sep 2008
    Quote Originally Posted by MuscleMan305 View Post
    LT is the primary tank, and LT is drivers side, RT is passenger
    TNMM
    Magnum Sold
    Mag05's Avatar
    Mag05 is offline The HEMI that roars
    Jun 2008
    Brantford, On. Canada
    Hi everyone; Trying not to hijack, but I have an 05 Mag R/T, I have personal settings in the speedo cluster, and can check klms. left of fuel, cd/radio info, why do I not have some of these other specs. that your speedo cluster shows? Different group rating? Cal
    SLP CAI, SLP Catback, SLP 25% underdrive pulley, 170 stat, Predator SLP tunes[2], Mopar TCM, no esp mod.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Your sending unit is bad,not the pump.
    BFNY PERFORMANCE
    RIP My Friend
    fnkychkn's Avatar
    Quote Originally Posted by V8Mag View Post
    as Hemi31 said, this looks like a level sensor issue.
    once fuel level dips below the driveshaft tunnel which separates the tank, the left should always have more fuel than the right unless you just made a high speed left hand turn and the fuel spilled over to the right side. this should rectify itself within a couple of minutes as the venturi pump transfers the fuel back to the left side.
    Quote Originally Posted by Mag05 View Post
    from our knowledge base:
    Putting the LX into diagnostic mode
    V8Mag's Avatar
    Sep 2008
    Well this was from it being towed on the trailor back so it could be how the fuel was being tossed around when on the trailer. How could I get a proper reading of how it should be being the car is just sitting now.
    TNMM
    Magnum Sold
    fnkychkn's Avatar
    does it not run now?
    did you try adding fuel?
    V8Mag's Avatar
    Sep 2008
    It started up on Saturday night but it started to spit and sputter, and no I havent tried to add any fuel.
    TNMM
    Magnum Sold
