How do you remove the inner front fender well rivots that hold the front facia on? I start pulling on them, but I'm afraid it's going to break the tabs on the facia off.
"Just because that's the way it is, doesn't mean that's the way it should be."
2007 MSRT8, FlowMasters 40's, Vortech V3 SC, Magnaflow Hi-flows cats, BC coilovers, Hotchkis F/R Sways, Razors Edge Strut Brace, DMH cutouts, Silver Box, BT Catch Can and Engine Bling
removed
Last edited by Warlock; 08-13-2009 at 08:28 PM. Reason: Moron didn't read it correctly
If you have actual one-time-use rivets on yours (they varied between years), you can cut the plastic washer away using a utility knife, and then snip the rivet with some side-cutters.
You can possibly get the side-cutters underneath the washer head without cutting it away first, but I think it's easier to give yourself some room to work by cutting the plastic first.
Hope that helps.
Found a tip on thread in this forum. Just punch out the pin with a small screw driver. Fastners are obviously not usable afterwards, but they should do come out fast with this method.
Yea, one time use only.
I replaced mine with the fender well clips from a 2002 Honda Accord (my previous car). Works Great and reusable.
Buy extras that resemble stock ones at Advance or such stores.
Hemi registry#00729
LxReJx
harbor freight has the plastic rivet gun and around 20 rivets for $15.
Here it is. You can call your local store if you have one near you and give them the item #.
http://www.harborfreight.com/cpi/cta...emnumber=97757
