Results 1 to 11 of 11
    STAGE 3 R/T's Avatar
    Jan 2006
    Argyle, Tx
    fog lights not workin
    ok, did a search on fog lights and fuses... guess i overlooked or its not there... well I push my foglight button and they dont come on. i drove around for a day or so with out my drivers side on, no rain here. went to check them out tonight and wala they dont work. what fuse would I look for the see if it didn't burn out...
    fergyr31's Avatar
    fergyr31 is offline LX Newbie
    Oct 2004
    Make sure your high beams aren't on. That will disable the fog lights.
    Thirsty's Avatar
    Thirsty is offline 2005 SXT AWD
    Feb 2006
    Northern NH
    Front fuse box - F7
    2005 SXT AWD
    1986 Thunderbird TurboCoupe
    FloridaRT's Avatar
    Ocala, Florida :-)
    On my 05' Magnum, you need to have the headlights (low beam) or running lights on, for the fog lights to work. The fog lights won't come on unless some other light source is on.
    Bob
    boggart's Avatar
    Pittsburg, KS
    Quote Originally Posted by hawaiiHEMI
    As in only one bulb on? If so, sounds like the other burned out to me. Warranty item?
    quarky42's Avatar
    quarky42 is offline LX Guru
    Jan 2006
    Las Cruces, New Mexico
    My fogs only come on when I have the headlights in the "normal headlight far right" position on the switch and then push the fogs button.
    I doubt this is the problem you are experiencing, but just making sure. I believe this is what FloridaRT was trying to describe.
    Did the radiator cap mod: SRT8 is here....
    The Hemi says, "VROOOM!" Hemi Registry #00420
    Jan 2006
    Argyle, Tx
    that was the problem... gotta get a new one! thanks!!!
    Quote Originally Posted by Thirsty
    Front fuse box - F7
    JamminWagon's Avatar
    Cheyenne, WY
    Go to you local dealers and see if they will program "Export" mode for the foglamps. This enables them with highs. When I installed my FL, the car was already in xport mode.
    Jan 2006
    Argyle, Tx
    cool, will ask them, i know I will get that dumb look..
    Quote Originally Posted by Semi-Hemi
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    Here are the details on how to enable fogs with high beams.
    From the starscan main menu, select vehicle prep,enable fog lamp output, start,make sure they are enabled,click next, set to export mode,finish.
    That should help your dealer when they go to do this for you. Of course that just depends on if they do it for you.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    Jan 2006
    Argyle, Tx
    thanks! gonna have them do that! love that extra light!!!
