Results 1 to 4 of 4
    ZMagnum's Avatar
    Tucson, AZ
    Flash with lock/unlock.
    I'm not sure how it happened but my blinkers no longer flash when locking and unlocking. The headlights still come on.
    I don't have the EVIC so I can't just bring that feature up on a screen and change it.
    I'm thinking that there must be a key sequence with the RKE to turn this feature on and off. If someone knows what it is please post it. This should also be in the KB.
    NC-SXT's Avatar
    NC Coast
    Actually its in the manual. You can program the lock ,unlock in several ways. One way I did is to make sure all doors unlock when I open drivers door.
    Not sure which page.
    WWW.DodgeMagnumGrille.com
    ZMagnum's Avatar
    Tucson, AZ
    OK, I'll check again. Thanks.
    Quote Originally Posted by NC-SXT
    ZMagnum's Avatar
    Tucson, AZ
    LX
    OK, I got it working again but the manual is wrong. The 2005 Magnum manual has it backwards between turning "Flash Lights on Lock/Unlock" on/off and "Unlock All Doors on first press." Here is the correct way. This should go into the KB:
    To turn off/on "Flash Lights On Lock/Unlock":
    1. Press the UNLOCK button for 4 to 10 seconds.
    2. While the UNLOCK button is pressed, (after 4 seconds) press the LOCK button. Release both buttons.
    The "Flash Lights On Lock/Unlock" feature can be reactivated by repeating this procedure.
    To turn off/on "Remote Unlock Driver's Door 1st":
    1. Press the LOCK button for 4 to 10 seconds.
    2. While the LOCK button is pressed, (after 4 seconds) press the UNLOCK button. Release both buttons.
    The "Remote Unlock Driver's Door 1st" can be reactivated by repeating this procedure.
    To turn off/on "Sound Horn On Lock":
    2. While the LOCK button is pressed, (after 4 seconds) press the PANIC button. Release both buttons.
    The "Sound Horn On Lock" feature can be reactivated by repeating this procedure.
    I tried this last procedure using the UNLOCK button and PANIC button together. It didn't seem to do anything. If anyone else finds that it changes something please let the Forum know.
    Automatic Door Locks at 15mph:
    For vehicles not equipped with the EVIC, the Automatic Door Locks can be enabled or disabled by performing the following procedure:
    1. Close all doors and place the key in the ignition.
    2. Cycle the ignition switch between LOCK and ON and back to LOCK 4 times ending in the LOCK position.
    3. Depress the power door lock switch to lock the doors.
    4. A single chime will indicate the completion of the programming.
    Automatic Unlock:
    3. Depress the power door unlock switch to lock the doors.
