Pappa John offered to make me one after seeing me constantly bitching about our skinny shifter shaft
Thanks John
Thanks John
yea you still can see the skinny part at the bottom though
MOD LIST : NOT ENOUGH!!
Al,
Thanks for posting the pics, I would have liked to make it so you couldn't see the skinny part at the bottom, but then you couldn't power shift it because it would rub...About the only thing you can do is put a small piece of shrink tubing down there to cover the shiny part...If you look at the one Hurst makes, you can see a little at the bottom too...
I know how to solve that problem....
Someone needs to design a "low rise' style shifter boot. That would be cool.
The boot would hide the transition on the shaft.
The shaft could even be fatter.
2006 Charger SRT8
BES/HHP Stage II Heads/Cam/Intake/BBK 85mm TB
Hotchkis sways and Vredestein 275/40/20 Ultrac Sessanta paws
Predator + CMR = "Custom Dyno/Street Tuned PCM"
just modify the gate. i bet BT can do that.
