Results 1 to 10 of 10
    legmaker72's Avatar
    legmaker72 is offline Saving the world one leg at a time!
    May 2005
    Jacksonville, Florida
    Question Fiber glass Body Work question
    All fo you with body work experience, I need your opinion.
    I'm getting my hood prepped for paint and having the fake vents filled in as well. Some of you here have said to let the hood cure after prepping before the final paint....drive around with the unfinished hood on for a while.....
    The body shop guy said it wasn't necessary to do this and any ripples or shrinkage could be wet sanded out.
    What do you guys think about this? Should I be a little wary?
    Thanks for your help!
    Take care,
    Christopher
    ________ ________
    "I complained to God that I had no shoes, until I met a man with no legs"
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    I guess do as he says and if it doesn't go to your liking make him repair for free, after all, you're following his suggestions.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    I would let it cure a bit.And don't drive around with it in bare glass,make sure there is a gel coat or at least a sealer coat on it.
    BFNY PERFORMANCE
    RIP My Friend
    Charg-um's Avatar
    Charg-um is offline <---- M for Mwaa Haa Haa
    May 2006
    South Fl, near the beach.
    It also depends on the quality of the products they use. Higher quality products dont shrink as much.
    Painter Paul.
    #001 "The original"
    Sponsored by High Horse Performance Inc and Billet Tech
    Who wants to be a Charg-um ? :
    legmaker72's Avatar
    May 2005
    Quote Originally Posted by Charg-um View Post
    How can I tell what products they use and if they are good quality or not? Which ones are better than others?
    Take care,
    Christopher
    ________ ________
    BurntOrange's Avatar
    BurntOrange is offline LX Padiwan
    Nov 2005
    Jacksonville, FL
    It would be better to put it on drive it for a few days ,then have to return and have the work done over and loose your ride again for a week.
    Go-ManGo! 2528
    SRT Suspension, Airaid CAI, Diablo Predator, Magnaflow Catback, Stealth Auto Headlights, Blinker MOD, Nitto 420s, OEM Chromed CSRT Wheels, Custom CF Engine Cover (By ME.), SRT Diffuser, 180 T-stat, some day Cam and Heads, BT Dash Tag.
    DragginWagon's Avatar
    DragginWagon is offline LX Padiwan
    Nov 2005
    Atlanta, Ga
    I had mine filled in on my R/T, took them 4 times to come close to even getting it looking good, and then as time went by it kept looking worse and worse!
    legmaker72's Avatar
    May 2005
    Quote Originally Posted by DragginWagon View Post
    Yikes! Maybe I will just forgoe the vent fill in. I like things easy...no problems...
    Take care,
    Christopher
    ________ ________
    Charg-um's Avatar
    May 2006
    If he says there wont be a problem, then he is most likely using high end products.
    You should fill them in if that is the look you want, like said above, ask him to get it into primer, and tell him you are more comfortable letting it "shrink back" before they do the finish work.
    Painter Paul.
    #001 "The original"
    ESAD is offline www.billet-customs.com
    FORT PIERCE, FLORIDA
    I would agree with this statement.
    Even though todays high end products don't shrink much. It is advisable to let it sit a bit.
    When doing full restorations that require the entire car to be primed and sanded, a good shop (that has time) will let the primer sit for a week or more before a final wet sanding. Then prep and paint the vehicle.
    Nothing may happen, but it's a little insurance if you can wait.
