Results 1 to 11 of 11
    cm2005300's Avatar
    cm2005300 is offline The New "Milli Vanilli"
    Bc
    fascia removal question
    i have read the removal procedure and is there any danger of setting the front airbags off while doing this??
    MOD LIST : NOT ENOUGH!!
    TBYDaytona40's Avatar
    TBYDaytona40 is offline LX Padiwan
    Jul 2007
    Las Vegas, NV
    not with second generation airbags. I believe the vehicle needs to be moving over 5 mph before deployment.
    Top Banana Daytona 40/4000. I support the following vendors, who in turn support my work: Danko, MPSC, Franks!, RiderGraphics! BilletTechnology!, AEM, DMH, Rockblockers, DiabloSport
    grinner's Avatar
    grinner is offline ModdinArt.com
    Dec 2004
    stl
    comes off with just platic rovits and some screws.. Goes on and off in less than an hour, believe it or not.
    cm2005300's Avatar
    Bc
    Quote Originally Posted by grinner View Post
    yea i bleive it now the belly pan screws do those just screw right in or is there a nut on the other side to screw into?
    cm2005300's Avatar
    Bc
    Quote Originally Posted by TBYDaytona40 View Post
    good to know so no one has had a problem with them then?
    tommyzdesign's Avatar
    tommyzdesign is offline just an lxer
    Jun 2005
    anywhere theres a Lxer in need.....
    nope, you wont have any chance of setting those off.
    z
    cm2005300's Avatar
    Bc
    thanks bro
    Nightshade's Avatar
    Nightshade is offline LX Guru
    Kitchener, Ontariooooo
    Quote Originally Posted by tommyzdesign View Post
    z
    Just don't use the method I used to get the front facia off.
    It does set off the airbags.... and is probably the most painful way to mod the car... (and thankfully, I was not the one at fault)
    cm2005300's Avatar
    Bc
    Quote Originally Posted by Nightshade View Post
    SORRY MAN ILL TRY TO NOT DO IT THAT WAY BUT IF I GET PISSED I CANT PROMISE ANYTHING !
    Nightshade's Avatar
    Quote Originally Posted by cm2005300 View Post
    Facia can be removed in like 15 minutes once you know what you are doing.. removing the dozen or so screws on the bottom belly pan is the most time consuming part...
    And don't get pissed and beat up your car.. You will be like me and miss having an LX.. (insurance company wrote it off as a total loss)
    cm2005300's Avatar
    Bc
    i will try not to !!
