Results 1 to 10 of 10
    FloridaRT's Avatar
    FloridaRT is online now LX Oldtimer
    Ocala, Florida :-)
    Question Explain TPMS To Me... please
    Okay, so I have a 2005 and it doesn't have TPMS.. (Tire Pressure Monitor)
    Just what is it and where does it show a warning if your tires are low?
    My big question is about the wheels;
    Are there 2 holes in the rim? one for the valve stem and one for the tire sensor?
    Or does the TPMS sensor replace the valve stem?
    I ask because I may be in the market for some nicer wheels in the future and want to clear up any questions about TPMS.
    Any help would be appreciated.
    Bob
    BTW, I forgot to post that my 4 year anniversary with my Magnum was on 07/18
    My how time flies.
    Twisties's Avatar
    Twisties is offline Got Rope??
    Diging a hole in the desert
    Quote Originally Posted by FloridaRT View Post
    Yes that is what it does
    No only one hole the sensor is part of the valve stem
    Bob
    My how time flies.
    hope this helps
    Before you criticize someone, you should walk a mile in their shoes. That way when you criticize them, you are a mile away from them and you have their shoes.
    "Those that beat their swords into ploughshares will plow for those that did not."
    "There are four boxes to be used in the defense of liberty: soap, ballot, jury and ammo."
    SeadooSandi's Avatar
    SeadooSandi is offline LX Jetski tower
    May 2005
    On a lake in Texas
    On my '07 I have two holes in the rim, one is valve stem and the other is for the TPMS.
    '07 Magnum RT RWD Steel Blue with Road & Track package, NC-SXT silver honeycomb grill, 20" Foose Nitrous Chromes
    Other Rides
    '01 BMW Z3 2.5i Roadster
    Watercrafts:
    '97 Seadoo GTX - Hydroturf matting mod
    '05 Crownline 202 BR with duoprop
    Misc Toys
    2010 Wildcat 31TS 5th Wheel
    The last time I refused a beer I didn't understand the question.
    Twisties's Avatar
    Is that on your Foose Nitrous?
    Carfinish's Avatar
    Carfinish is offline Capeeesh!?
    Nov 2005
    White Plains NY
    Bob TPMS I believe was not an option on the 05 Mags...meaning the programming was not there...although if yours was later may have been.
    RIP
    12.869 @ 102.02 Stock 5.7 w/ C&L, Predator, JBA Cats, Volant catback, DRs & skinnies
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    check ebay for an after market TPMS system.. it is not possible to add the TPMS to a 2005 car.. I have tried.. you need 3 wireless modules, which is easy to wire in, but the damn cluster doesn't have the software for the TPMS.. and you can't use a 2006 cluster because the hardware is different..
    so I just got this:
    http://cgi.ebay.com/ebaymotors/TPMS-...spagenameZWDVW
    I set the receiver in my console behind the rear air vents.. (have to remove the console to put it there) with some velcro and hard wired it fuse 18 in the trunk so it is switched with the ignition..
    mounted the display in the upper left corner of the windshield so it is out of normal view but at a glance I can see it..
    works great, tells me tire pressure, and tire temp, and beeps if the pressure drops below a present I determine myself, or if there is a leak.. (slow or rapid loss of air)
    FloridaRT's Avatar
    Ocala, Florida :-)
    No No No, you guys are missing the point of my questions.
    I do not want TPMS on my 05' car, I was just asking how it works and if there are 2 holes in the rims that have TPMS.
    In the chance I buy some factory wheels (in the future) that are equiped with TPMS sensors, will I have any problems putting them on my car?
    So if a wheel had TPMS sensor on it, there would be 2 holes in the rim?
    One hole for the valve stem and another hole for the sensor? Right?
    If I didn't want the sensor in the wheel, is there something to plug up the hole?
    Let's try this again..................
    please
    Bob
    Apr 2006
    no the Valve is the TPMS sensor. OEM wheels have one hole and the valve/sensor looks like this: you can replace with a regular valve without issue.. should only have ONE hole.. not TWO.. I think GM had a system with 2 holes couple years ago (2001 or so) not anymore though..
    some aftermarket wheels may have 2 holes because the sensor is designed to go on the curve of the rim, and some aftermarket wheels have valves on the middle flat part of the rim, requiring a second hole on the curve for the TPMS as the TPMS sensors are angled..
    hope that makes sense.
    FloridaRT's Avatar
    Ocala, Florida :-)
    Thank you!
    That's the info I was looking for..........................
    Kiss Kiss
    LOL
    Bob
    May 2005
    On a lake in Texas
    Quote Originally Posted by twisties View Post
    Yes.
    Other Rides
    Watercrafts:
    Misc Toys
