Results 1 to 4 of 4
    Xyrenn's Avatar
    Xyrenn is offline Coffee r delicious.
    Apr 2008
    Charleston, SC
    EVS I Alarm...programming/overide button?
    Need to change the shock sensor settings on this alarm so it stops chirping at me everytime someone farts to close...
    Manual says I need to press the programming/overide button located under the instrument panel for a few seconds to put it into the mode, but uh I can't seem to find it.
    #99 of 2000 Torred
    "The Torred Dodge Charger Daytona that just passed you on the freeway has been scientifically proven to be the fastest color in the universe when applied to a Dodge Charger." ~Urban Dictionary.
    EPIC SRT's Avatar
    EPIC SRT is offline Go Daddy! GO!!!!
    Feb 2009
    Merced, CA
    Not sure if the same on the Charger and Magnum, but.....
    On mine, the manual says that the dealer should have located next to the OBDII plug. Mine is located on the right side of the OBDII plug. You may have to remove the panel the covers the underside of the dash in order to locate it, and/or the panel under the steering wheel.
    Xyrenn's Avatar
    Apr 2008
    Charleston, SC
    Ah cool not sure if i checked that near to the port ill give it a looksee thanks.
    #99 of 2000 Torred
    Xyrenn's Avatar
    Apr 2008
    Charleston, SC
    Ended up taking it to the dealer who put it on. Turns out they never actually mounted the button so it was just hanging at the end of a wire tucked up under the dash.
    #99 of 2000 Torred
