Results 1 to 11 of 11
    Fawn's Avatar
    Fawn is offline 2nd Gen Camaro Lover
    Nov 2005
    Granite Falls, WA
    Question Electrical Gremlins?
    This is odd...anyone ever have this happen?
    Driving to work yesterday AM I turned on my left signal and it made a strange loud pop and then started clicking/flashing super fast. It has continued to flash and click at this hyper speed ever since. However, the right signal still flashes at it's normal slow speed.
    Is this a sign of an electronic flasher getting ready to die?
    Fawn
    2005 Dodge Magnum 5.7 HEMI
    Midnight Blue, fully loaded
    (My other car is a 73 Camaro RS 350)
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by Fawn View Post
    I'm not sure about our rides. But I know on my fords, when a turn lamp blows, it does the same thing. Have you checked your signals to make sure they are working?. That's the only suggestion I got for ya.
    LtlDad's Avatar
    LtlDad is offline LX Padiwan
    Nov 2004
    OC, CA
    I would guess the same thing....one of the exterior bulbs is out.
    2005 Mineral Gray SXT
    HAS SOME STUFF...
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    hmmmm...I checked the front it works, flashes just as fast as the relay click, I didn't check the rear...I'll look at it.
    Fawn
    0nothing's Avatar
    0nothing is offline I saw what you did!!!
    Baton Rouge
    I would say it is the turn lamp that blow out.
    K&N Air Filter, flashpaq V1.06 I need more mods.
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    OK...so I hopped out to check the signal bulbs while it was hyper flashing. The left rear was out. Alright, problem solved. EXCEPT it stopped hyper flashing.
    I drove to Shucks to get a bulb, turned the signal on, and it's back to slow pace and all the bulbs are working again. I turned the car on and off, did it in accessory mode and same thing - flashing was back to normal and the bulbs all worked.
    Some guy thought I was crazy running around the car looking at all the lights working. lol
    So I went in and bought bulbs anyhow. Damn thing worked fine the entire drive home (30 miles). Worked fine when I got home, and came to realize that pulling that rear bulb is not going to be an easy task... so eventhough I decided to replace it anyhow, I still haven't done it.
    Then this morning the hyper flashing was back again while driving and I assume the signal was NOT working because some people got upset with me on the freeway. lol
    So what do you think? Is a bulb going bad or am I having flasher issues or electrical problems?
    I suppose the only way to know is to start replacing stuff: bulb, then flasher, then cry. ack!
    Fawn
    SmoovC's Avatar
    SmoovC is offline M45 Maniac
    Apr 2006
    Graham, Kracka'!
    I had the same kind of thing happen on mine. When I replaced all of the bulbs with LED bulbs, one of the resistors for the turn signals had a cold solder joint from the manufacturer.
    It would flash real quick at first, then act as normal. The only thing I could think of is that the computer is looking for a specific load, and does not find it, therefore the variance in flash rate.
    Bottom line: replace the bulb, and all will be good!
    2006 Infiniti M45: Diamond Graphite Metallic, Premium Package Option Group w/ Mobile Entertainment System, Tein H-Techs & KYB Lowered, Magnaflow Exhaust
    2000 Dodge Dakota C/C R/T: Flame Red 5.9L, 1 of 800 Produced, Belltech Lowered, 20" R/T Replica Wheels, Flowmaster Exhaust
    More pics at:
    Visit us at:
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    Quote Originally Posted by Magnum Maniac View Post
    Well...hopefully it isn't a loose connection somewhere and it really is just the bulb. I'll try to disassemble that darn tail light tonight when I get home. grrrrrr...
    Fawn
    NC-SXT's Avatar
    NC Coast
    Just replace the bulb. Probably just a element going bad. Remember dont drop the wing nuts.
    WWW.DodgeMagnumGrille.com
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    Quote Originally Posted by NC-SXT View Post
    LOL....ya know, I popped open that access panel in the dark out in the parking lot. I put my hand in there and felt around and thought "crap..is that some huge wing nut?" just from feeling it. I didn't feel a way for the light to come with it so I'm thinking, "I must need to pulll that huge wing nut and then do something else to get the lense off....
    Pulled out the owners manual (duh...it even said when the flasher goes faster that a bulb is out) and it said EXACTLY what I figured...
    Fawn
    DA X 6's Avatar
    DA X 6 is offline Always backing into trouble...
    Bartlett, IL
    Same here...
    I had the same experience last night, and I'm just about to head out to the garage to replace the bulb on the left rear.
    One semi-interesting thing I noticed was that when I hit the "lane change" function, it flashed six times on the left vs. the usual three. I'm guessing that it's a timed function, rather than "three and out."
    Speaking of "three and out," my Illini are about to go through the meat grinder at Happy Valley, so I'd better get going...
    sig by ElCobra44 The General Sherman / 2006 Charger R/T, Bright Silver
    Poor Man's mods:
    Auto Headlights/Hood Struts/Visor Stickers/Lock Pin O-rings/Blinker Mod/RD Hardwire/Cabin Air Filter/Storage Compartment
    Silver Calipers/Honeycomb Grill w/R/T badge/Belly Pan Mod/GTS rain guards/aFe drop-in air filter/Gorilla Lug Nuts/Rear Blinker Mod
    Backup Camera/Fumoto valve/PAC Audio aux. input/SilverStar fogs
