Results 1 to 5 of 5
    bigfuchs44 is offline LX Newbie
    Apr 2008
    chicago IL
    EGR valve replacement?
    Has anyone replaced and EGR valve on an 05 maggie SE?? Mine is shot and need to get it replaced for my emissions test. I have the part ordered already just wondering if there is a write up on it here that im not finding. Any help would be great. THANX
    fuzzycali's Avatar
    fuzzycali is offline Space City LX Nawfside AC
    SPRING,TX
    HERE U GO
    1. EGR system components and location. Upper tube (2), EGR valve (1), and Lower tube (3).
    2. Disconnect negative battery cable.
    3. Remove purge solenoid from bracket.
    4. Relocate the purge solenoid.
    5. Unlock and disconnect the electrical connector from EGR valve.
    6. Remove the bolts from the EGR tube to exhaust manifold.
    7. Remove the lower tube bolts to EGR valve and remove tube(3).
    8. Remove upper tube bolts to EGR valve (2).
    9. Remove the EGR valve mounting bolts (1).
    10. Remove valve from vehicle.
    11. Clean mounting surface.
    2007 Charger Road & Track R/T
    fuzzycali's Avatar
    SPRING,TX
    INSTALL
    2. Install EGR valve.
    3. Install the EGR valve mounting bolts (1).
    4. Inspect rubber silicone seals on intake manifold end of EGR tube.
    5. Install upper tube into the intake manifold, being careful that the silicone rubber seals are correctly installed and undamaged.
    6. Install new gasket between the EGR valve and upper tube and install bolts (2).
    7. Install the lower tube to exhaust manifold.
    8. Install new gasket between the EGR valve and lower tube and install bolts (3).
    9. Tighten the lower tube to EGR valve bolts (3) to 11 N·m (95 in. lbs.) torque.
    10. Tighten the lower tube to exhaust manifold bolts to 31 N·m (275 in. lbs.) torque.
    11. Tighten the upper tube to EGR valve bolts (2) to 11 N·m (95 in. lbs.) torque.
    12. Tighten EGR valve to cylinder head bolts (1) to 31 N·m (275 in. lbs.) torque.
    13. Connect the electrical connector to EGR valve and lock.
    14. Relocate the purge solenoid.
    15. Install purge solenoid to bracket.
    16. Connect negative battery cable.
    17. Using a diagnostic scan tool, erase any previously recorded DTC's (Diagnostic Trouble Codes).
    mgrasber is offline LX Newbie
    Feb 2009
    I had to have mine replaced too... here are the steps I followed -
    1) call mechanic
    2) drop car off at mechanic
    3) pick car up from mechanic.
    you'll find it might cost a bit more but totally worth it in my eyes!
    LATIN MAGNUM's Avatar
    LATIN MAGNUM is offline LX Newbie
    binghamton ny
    hade the egr codes on my 2.7 and spoke to a mec at work and he told me to replase purge solenoid did that pulled fuse #11 for min and put in and drive about 30 miels and no more codes
    05 cool vanilla se led tails lights hids head lights rt 35% tints rims fog lights.wifes car 06 sxt silver hids
