Results 1 to 10 of 10
    monty1269's Avatar
    monty1269 is offline Looking for a job too...
    Aug 2005
    Pompano Beach, Florida
    dropped out - transmission - FNKY HELP!!
    Scenario-
    Driving on the way to work...using the paddle (SC Perf setting). Just like any other day... I driving "normally" - like the average Joe, just cruising along in 3rd...
    Next thing I know, I'm looking at the "D" and there is NO POWER TO THE WHEELS! I give it a little gas, and the RPM's run up a little, and yet NOTHING to the wheels!! I repeat it ...RPM's go up, but the same thing... SO.... then, while still moving down the road - no traffic- I move it up into nuetral, and then put it back into "D"...coast for a second, and then ALL things return to normal...
    What the hell?? Any idea folks??
    Billet Tech Goodies EVERYWHERE Diablo tuned!! Inertia SPARTAN CAM 214/218, 113 LSA, 3.06 gears, FTI 3600 TC, 17 X 8.5 Borbet TS w/ 275/40 Hoosiers : Hemi Registry 0436
    Best 60'= 1.896 (stock TC and gear) ET= 12.841 (pre-Eagle heads & 6.1 intake manifold)
    Super T's Avatar
    Aurora, IL
    The little gremlin inside your tranny must have needed a bathroom break
    (seriously... i hate automatic transmissions).
    Really though, sounds like your trans slipped out of gear. Could have been an electronic hiccup, could have been that it didn't fully engage the first time you shifted... who knows. It's definitely something to keep an eye on. With no codes and the car acting normally, I can already hear the dealer telling you 'could not duplicate condition. no repair performed.' If it happens again though I'd definitely start making a stink about it.
    fnkychkn's Avatar
    greasy cardboard box
    any DTCs?
    monty1269's Avatar
    Aug 2005
    Don't know.... I guess I can connect the SCtuner to tell me that huh? (I dont have the EVIC option....
    Wait...isn't there some way to display these codes even tho I DONT have the evic?
    PHANTZM's Avatar
    PHANTZM is offline Formerly known as Suipsycho
    Arizona
    Ignition off, on , off, on, off then on should bring up the codes if any...at least thats how I think I did it on mine. It shows the codes on the odometer. (scratches his bald head)
    Pretty sure it is correct.
    Just did it, thats how it is. Switch the ignition on/off 3 times leaving it in the on position last.
    ~Sui
    monty1269's Avatar
    Aug 2005
    THANKS!!-------running out to the parking lot now-----
    Edit: Well that didn't work...Or I've got no codes....
    Will the SCtuner show me the codes? (I THINK it will......??)
    PHANTZM's Avatar
    Arizona
    I was wrong, sorry. Switch between ACC and ON 3 times , then it will cycle through the codes if any and post done when finished. Dunno why I said off ..... sorry.
    ~Sui
    monty1269's Avatar
    Aug 2005
    THAT worked...NO CODES!!
    fnkychkn's Avatar
    keep monitoring it. if it happens again, try running with stock tune to eliminate the possibility of the tuner being at fault.
    azjetblu is offline LX Newbie
    Chandler
    happened to me a while back
    Same thing. Driving to work in D. audible "thunk" and I have no drive. Zizz motor, coast to side of road. Shut off and restart, everything good. As I drive home, pop code. I left next morning on a 2 week m/c vacation. When I returned, start Magnum, no code. This was late July no trouble since. Go figure
    Quote Originally Posted by monty1269 View Post
    Scenario-
