Results 1 to 11 of 11
    cm2005300's Avatar
    cm2005300 is offline The New "Milli Vanilli"
    Bc
    driving me NUTS!!!!
    i have this sound from the front end ... whenever im driving slower and go over a bump or something i get from both sides a sound like clunking and rattling ....only happens when im going slow ....just had tie rod on passenger replaced so thats not it... maybe bushings on sway bar? wish i could get a sound but it wount come out right while driving
    MOD LIST : NOT ENOUGH!!
    cm2005300's Avatar
    Bc
    Bump
    Nuclearjack's Avatar
    Nuclearjack is offline I drive!
    Halifax Nova Scotia
    It is one or all of the below.
    Tie rod ends. inner or outer.
    Sway bar links/ bushings
    heat shield near exhuast.
    Struts
    Tenision rod.
    Tbird100636's Avatar
    Tbird100636 is online now Master ASE Certified NON-Chrysler Tech
    Braintree, Massachusetts
    Cool
    Quote Originally Posted by cm2005300 View Post
    A way to check front sway bar bushings on RWD LXes is to unbolt the sway bar with the links still attached. Grab the bushing. If the bushings are closed completely shut but don't fit the bar tightly (you can move the bushings back and forth noticeably against the bar) then you need sway bar bushings. They should fit the bar tightly and be hard to close. You can also check the links for looseness with the bar partially hanging. I just did a set of tension struts this week on a customer's car. These were really bad, tons of up and down play on the ball joint end, bushings on the other end were spliting. Caused a high pitched metal-to-metal sound over bumps and when applying the brake. The same car also had bad sway bar bushings causing more of a low pitched knocking.
    www.ramtruckforums.com
    linkdx_245 is offline LX Padiwan
    Oct 2008
    Bump
    Can someone tell me what bump means?
    Posted via LXFMobile
    Halifax Nova Scotia
    Quote Originally Posted by linkdx_245 View Post
    it has many meanings. girls have two bumps on thier chest.
    There are speed bumps on the road.
    but in this case it describes posting in a thread simply for the purpose of moving it to the top of the list so more people will read it. Some people would add another post while others are more clear with their invention and simple state that they are bumping their thread to the top of the list. "bump"
    xevilpetex's Avatar
    xevilpetex is offline Terror of the Northeast
    Long Island, NY
    I would check your swaybar endlinks. They may not be tight enough.
    Oct 2008
    Quote Originally Posted by Nuclearjack View Post
    Lol that's for the bump lesson
    cm2005300's Avatar
    Bc
    Quote Originally Posted by Tbird100636 View Post
    Thats the sound i was trying to describe !! so ill have those fixed and go from there
    magnumman426's Avatar
    magnumman426 is offline Smoke 'Em if ya Got 'Em
    Feb 2006
    New Jersey
    From past experience in the shop, I'd replace the Swaybar End links and sthe stabilizer bar cushions. Usually if the torsion struts are torn up, it will cause erratic steering wheel hop when you hit bumps in the road.
    cm2005300's Avatar
    Bc
    Quote Originally Posted by magnumman426 View Post
    no its just a light clunking /vibration sound very faint
