Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Motor's Avatar
    Motor is offline pwrparts.com | Eric von Motor
    Chicago, Illinois
    Exclamation Driveshaft Vibration - Aftermath...
    Ok, so as some of you may know i had a bad d/s vibration just like Jweezy...
    Thanks to Junior/Meister i got my hands on a new d/s with the rear coupler and also bought the mid brace w/ the new bearing...(whats the technical term for that damn piece??)
    Now the car pulls tight when i hit the gas...no vibration and hauling ass in the hundred twenty area. Its so nice to have the car back
    In any case here are the pix of the rear coupler (front was fine) and also my brace...rough riding...
    Brace
    RIP - 05 Dodge 'Dirty Whore' Magnum R/T (12/7/11)
    Current - 11 Ford 'Whorus' Taurus Limited - a step back from modding
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    WOW... that brace is DONE...
    -Ryan
    <<<clicky...
    '93 1500 SB - 226k, '05 Magnum RT - 17k, '80 El Camino - 84k
    netnathan's Avatar
    netnathan is online now Not the Momma
    Corona, CA
    I can see how if the drive shaft came loose the "insulation barrier" would be ripped up.
    Where did the brace damage come from? It looks lie you bottomed out..
    I am curious because I am not running the brace. My Magnaflow piping rattles on it.
    2006 Charger SRT8
    BES/HHP Stage II Heads/Cam/Intake/BBK 85mm TB
    Hotchkis sways and Vredestein 275/40/20 Ultrac Sessanta paws
    Predator + CMR = "Custom Dyno/Street Tuned PCM"
    ekaz is offline all gone
    Jun 2006
    CHICAGO
    I think it was more like grounding than bottoming out.
    Unlawful Gathering
    Click for details!
    2009 MBP GCSRT8
    Powered by PWR
    Shifted by SHR
    Tooned by Johan
    Blinged by Billet Technologies
    MoPOWeR-349's Avatar
    MoPOWeR-349 is online now Whiskey Tango Foxtrot: Buster Buster
    Nor Cal
    Was the coupler damage easy to see when bolted in place? Wondering if we all should inspect these every once in a while...
    crhemi's Avatar
    crhemi is offline LX Padiwan
    Dec 2005
    Kauai, Hi
    So whats the cause of the coupler failure?
    UPS92008's Avatar
    UPS92008 is offline appetite for destruction
    Sep 2007
    Carlsbad CA
    Dude motor? Driving around beating the **** outta speed bumps?? Hehehehe.
    20" Vipers/ Afe Stage 2 Pro Dry S/ BT bling/
    Stealth lights/ mopar/ KILLERGLASS
    CORSA/ EBC USR's/ HOTCHKIS/ Diablosport/
    HID 5000K/ BMC/ jj's precision guesswork/ MGP/
    modern-muscle is offline Supporting Vendor
    Apr 2008
    Would you guys have any interest in us making a billet piece for the front and rear? It would take some slop out of the drivetrain. The GTOs suffer from the same issue with their rear rubber coupler. All aftermarket shafts come with a billet coupler.
    www.modern-muscle.com
    630-898-5933
    61 Kendall Point Dr.
    Oswego, IL 60543
    brad@modern-muscle.com
    Dantra's Avatar
    Dantra is offline I shaved both of our asses
    Dec 2007
    Indiana
    Great pics (again)
    And how the hell did you fit under there
    Fargo59's Avatar
    surely you mean billet with bushings in it. with no bushings, there would be a vibration in the driveline due to slight angle changes.
    Apr 2008
    No, it's there as a shock load damper or cush drive. By removing the rubber you will transfer power faster to the rear end. The rubber couplers are not there as a U-joint. We have seen really good results with billet couplers on other similar setups. Granted, we'd need to test it on this application obviously, but I don't think it would cause a vibration issue.
    630-898-5933
    Oswego, IL 60543
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Quote Originally Posted by modern-muscle View Post
    As long as the pinion angles are correct and the shaft is in phase.......I can tell you for a fact the LX shaft is out of phase as it is off center and may require a CV joint on one end.
    I do agree that a solid joint would transfer power much better but I also believe the rubber coupler is the only thing keeping the rear differentials on these cars intact.
    BFNY PERFORMANCE
    RIP My Friend
    Apr 2008
    Yeah, I haven't looked at it very close so I'm sure you're right. Maybe one billet coupler and one rubber.. don't know yet. It is easy enough for me to design and machine one real quick. I'll play around with the idea and see what I can come up with. I have some things in progress that will solve the whole grenading driveline thing too.
    I'm just looking to improve the drivetrain that Mopar skimped out on you guys.
    630-898-5933
    Oswego, IL 60543
    Hemi31's Avatar
    If you do a solid joint I would also look into a beefed up center bearing and mount.I am pretty sure once all the slop is taken out of the shaft you will see those rip out of the floorboards.I know I ripped my fair share out of my 62' 409 Impala.With similar weight and torque off the line I am sure that we will see it someday on an LX.
    BFNY PERFORMANCE
    RIP My Friend
    Fargo59's Avatar
    the pinion angle is dynamic on these. it changes slightly while under load. mostly because the diff is mounted on 3 rubber bushings. ever driven an LX with NO coupler, or using 3 of the 6 holes? its like driving with square wheels.
