It seems the drivers side window switch came loose form the bezel and fell in to the door panel. I can get a new bezel, and/or window switch, but my question is, can I remove the bezel and window switch without pulling the whole door panel off? It looks like it all comes out through the top, without pulling the panel, any ideas?
'06 SRT8 300, AFE CAI, Predator 91 CAI, 12.85@108 HR#1438.
turn it sideways and slide it up, should come thru pretty easy, you might need a second set of hands one to hold it up and one to disconnect the 4 wiring harnesses..
"Scars heal... glory fades, and all we're left with are the memories made, Pain hurts, but only for a minute, Yeah life is short so go on and live it; Cause the chicks dig it" - Chris Cagle
I assume you mean after I pop the bezel off, right? Also, does the bezel just pop off?
safer to remove the door pad for the amount of work involved.
It isn't all that hard.. couple screws and push clips/pins..
2006 Lil Red Wagon SXT
Modlist : AFE Stage II, JBA Headers, Corsa Catback, 20" Vipers, Cross Drilled Rotors, Diablo Bob@SVS Tuned, Pioneer DEH-5000UB, 12" Enclosers, Halos, Low/Fog HIDs, Cuda Grille, TruFiber Chally Hood.
at the Track
My Garage
Mentoria Computer Consulting
