About 3 months ago one of my rear coupler bolts had broken in half after beding my rim form hitting a pot hole. I was having the same vibrations like in Jweazy post. I replaced all the bolts my self and it stopped about 90% of the vibrations but to me the coupler did not look completely strait its warped or bent a little. Since then vibrations have come back not as bad but noticable. So I took it to the dealer last week and told them that I needed my reaer axle looked at. I did not mention the work I did, I wanted them to find it there self and cover it under warranty. Well they told me the U joint looks fine and I have inner and outer tire rods that are loose. I was there for inspections and they tride to charge me 1400.00 for new tires which I dont need and the tie rods not under warranty. My question is do you think my tie rods are bad also and thats causing the vibrations or should I just replace the coupler like weezy did in his post. Also how much for that coupler I found tie rods prices form a recent post. It seems like were all having the same issues with the car.
