Results 1 to 10 of 10
    SRT80953's Avatar
    SRT80953 is offline M16 MOPAR Drag Team
    Aug 2008
    Renton
    Draining Coolant
    Anyone out there try draining your coolant?
    I turned drain plug but nothing comes out.
    I even removed upper hose but nothing comes out.
    Mike
    KN CAI, DIABLO, 180, ZOOMERS, NITTO NT555R
    Smoove06CSRT's Avatar
    Smoove06CSRT is offline Kiss my Rims.. They gots BIG lips!
    Nov 2005
    start car with teh cap off and the drain on the radiator open....
    2006 300cSRT8
    Fastest color...... Bright Silver Met.
    "OHH! A Strip Club.....I'll Get my sweat pants on!"
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    If you're dumping all of the coolant, you'll need to remove the plug on each side of the block with the cap off.
    440 Stroker Short Block 4sale!! (tentatively sold)
    2010 MSHS Stroker N/A Champion!
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    that tube can get plugged....a little air will clear it right out.
    Posted via LXFMobile
    PRoBLeMz's Avatar
    PRoBLeMz is offline Wow, this thing sure is....
    Fort Hood, TX
    Quote Originally Posted by MadCharger View Post
    where are these plugs at on the block? do they need to be replaced?
    Dodge Challenger 392 SRT8(Green w/Envy) Mods soon to follow!
    © © All names changed to protect the Innocent
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Quote Originally Posted by PRoBLeMz View Post
    They're on each side of the block, almost in the center. They're pipe threaded studs that require a hex key to remove. You can reuse them. Very messy too.....
    AIRWOLF's Avatar
    AIRWOLF is offline THE LADY IS BACK!
    CITY of NEW YORK
    What is the best anti freeze fluid to use?
    bigjim's Avatar
    bigjim is offline Damn Fast Grandpa!!
    Oct 2004
    LaFargeville, NY / Bolton, ON
    I have been using a shop vac for years on various engines from chevy small blocks to snomobile engines. Pull the upper rad hose, connect the vac and turn it on, shut it down in a few minutes. It will lower the level in the block below the deck so you can lift the heads without filling the jugs and having to clean up afterwards. I have NOT tried it on the hemis, maybe if someone does....
    05 Magnum RT 5.7 (Member ALLPAR.com 200,000 mile club) Rockinsrt8 shifter, Hemi reg #164 266,666 miles (c'mon John, I slowed down! NOT)
    Sidewinder, 6.1 pushrods, springs, underdrive pulley, SRT exhaust (donated by NHDave) headers to tips, all installed by Hemi31! Quaife, certain Pedders bushes installed, SRT Nivomats and Bilsteins. Police rotors and pads. HIR. Predator. LMI.
    1:19 NJMP Lightning
    1:45 Mosport
    1fastsedan's Avatar
    almost Mexico, CA
    Quote Originally Posted by chez1701 View Post
    Zerex G-05 is supposedly the same as the OEM Mopar coolant, just without the orange dye.
    AIRWOLF's Avatar
    CITY of NEW YORK
    Quote Originally Posted by 1fastsedan View Post
    Thanks I'm running a little low!!!!!!
