I was wondering if anybody had a step by step to replacing the door pulls in our cars. I assume the process is the same for all applications.
You will have to remove the door panels and you will see the two screws that you have to remove and then the handle will turn off. Then just do that 3 more times and you are done.
Thank you Bigal470
Thanks to Semi-Hemi
Door Panel Removal Step by Step *
WWW.DodgeMagnumGrille.com
The 2 screws that hold each door pull on the panel are torx t-27 if I recall.... you'll need that bit for sure!
--Bo
T-27???? I've only seen the bits come in increments of 5. Who knew?
I just yelled at mine really loud. eventually they fell off.![]()
MODS: Borla 112 exhaust•SRT8 suspension•Hotchkis swaybar•K&N drop-in filter•35% Tint•Auto Headlights•Chromed R/T rims•SRT grill•SXT Headlights•Daytona chin spoiler•300C interior door pulls•Custom "Monkey" leather armrest.
COLOR MATCHED: Custom engine cover•Air box•Shock covers•radio/shifter bezel•shifter•rear spoiler•lic. plate frame•splash guards•
Just did mine...everything worked out fine as per Semi-Hemi's instructions...
But what I did was go to the dealer and buy a clip to actually see how far it needs to be pushed in to release itself (which is only about 1/8") and I found a tool to do just that. While they are in the door and expanded it's REAL easy to over press the release pin and drive it thru the clip and into the bowels of the door...
Oh..also get a tool to pull the Xmas tree clips that don't come off with the door panel...a screwdriver will break them...
2006 Inferno Red Magnum R/T
It's got HIR's w/ Nokya Hyper Yellow Fogs, Painted Spoiler, Tinted Front windows, Black SRT grill and SXT headlights...
