Results 1 to 4 of 4
    JamminWagon's Avatar
    Cheyenne, WY
    Did it again, amp/sub area change
    I think im on about change 12312412 hahh.
    This WAS the "last change I will ever do"
    Got tired of polishing out the scratches in the plexiglass.
    So I decided to go back to the solid top with the amps completely hidded like before. (old pic, still have to cut new carpet)
    Now for the new
    Take a panel $8, Mirror $10, 2 sets of door edge protectors $5, 2 LED strips $20 and some adhesive $3 ($46 total)
    Take mirror out of frame and cut the door edge protectors to dress up the mirror edges, cross drill holes to hide wires, mount LEDs and you get this.
    Hook up portable car jumper to test
    Paint the panel black and mount the stuff
    Test it out in the car(remember still hav eto recover)
    And turn off the flash
    Cheyenne, WY
    Today's updates
    Added piano hinge and cabinet handle ($15)
    Instead of using a prop rod, going to use a replacement rod for the cover (only for showing) dang sun
    Now with some carpet down, not glued yet
    Still have to wire up the lights
    Fondy's Avatar
    Fondy is offline YUUUUUUUUUUUUUUUUUUP!
    Feb 2006
    Fond Du Lac, Wi. Member# 5136
    I LIKE IT!
    you keep changing it and it keeps getting better!
    :insert sig here
    Cheyenne, WY
    Thanks, just have to find a tilt switch. This way I wont have put a switch in. Now to work on the amp cooling. With the cold weather here, I have all winter to think about it haha.
