Results 1 to 5 of 5
    ASU_Magnum's Avatar
    ASU_Magnum is offline I'll be back...someday
    Nov 2005
    Phoenix
    Diagnostic Codes...Help
    Ok so I forgot to connect the MAF sensor before I started the car. Check engine light came on and I did the diagnostic entry thing.
    Got code 0113. I looked it up on the codes database and it says air intake temp sensor. I am assuming it will go away with a pcm reset?
    Also got code 061A and I couldnt find that in the database. Anyone know wtf this is?
    Thanks!
    2005 Magnum SXT Bright Silver - SOLD
    2006 Yamaha R6 Raven -STOLEN
    Quote Originally Posted by Zmagnum
    You are famous. You have the fat woman sittin' crack findin' Magnum
    RobAGD's Avatar
    Reston, Va
    The Temp will go away after 3 good runs buts it not a simple on off drive things you have to go X miles etc.
    The other code is missing something, letter or something else, you may want to recheck that one.
    -R
    ASU_Magnum's Avatar
    Nov 2005
    Phoenix
    well they both cleared after a pcm reset. who knows what the second one was.
    thewagon's Avatar
    thewagon is offline Hurry up and get here Summer!
    Jun 2005
    Sparks, NV
    The second code says to never forget the MAF sensor
    2005 Inferno Red Magnum R/T & 2010 RAM 1500 4x4 Hemi
    Retired USAF/USANG 22yrs, Det 2 23ADS, 274th CCSQ, 213th EIS
    fnkychkn's Avatar
    greasy cardboard box
    P061A-ETC LEVEL 2 TORQUE PERFORMANCE
    • When Monitored: Throttle motor is powered.
    • Set Condition: When secondary software determines that the customer requested output is not being achieved by the engine for a period of time. ETC lamp will flash
    Possible Causes
    PCM NEEDS TO BE PROGRAMMED
    PCM
    first time i ever saw that one. not sure what to make of it. any kind of tuner or chip on your PCM?
