ok i tried everything and the key just wont come out it wont even move to the lock position.i adjusted the shifter cable and that is not the problem,can someone please help
Had that once before. Try rocking the steering wheel each direction and twisting the key.
Good luck with it.
My Duster is getting an Inertia Motorsports HEMI!
Didn't you make it to the Texas ALL MOPAR event benefiting the Tx School for the Blind?
www.ramtruckforums.com
is this still the result from your pink thingy repair? have you adjusted the ignition interlock cable? if so, i'd be checking all parts were reassembled correctly. many have done this repair and i haven't read about anyone else with this problem ???
what i am thinkin is it must be something else, maybe the ignition switich is no good? plus if i do a diagnostic check on it will it show that plus how much does that cost to get done?
this is a mechanical issue. no electrical diagnostics.
KEY WILL NOT ROTATE TO THE LOCK POSITION.
1. Misadjusted Park Lock cable. 1. Adjust Park Lock cable. i posted instructions in one of your other threads.
2. Misadjusted gearshift cable. 2. Adjust gearshift cable. i posted instructions in one of your other threads.
3. Burrs on ignition key. 3. Remove burrs and cycle key several times to verify operation.
4. Binding or broken components. 4. Inspect system components and repair/replace components as necessary.
please update your vehicle profile in User CP so we don't have to keep guessing. thank you.
i looked up an ignition lock cylinder for an '05 LX: P/N 5083915AB $129.00 cad. + coding (approx $35.00).
