Results 1 to 8 of 8
    dgreekman's Avatar
    dgreekman is offline LX Newbie
    Cruise control stopped working
    I have noticed that my cruise control has stopped working. Took the car to the dealer who tested the actual switch and saw that it was sending a signal to the PCM. Either way they put in a new computer in the car, i loaded in my tune but still nada. Has anyone else have or heard of this with a CMR tune? Thanks in advance.
    K-1 Technologies 426 Stroker kit, Custom Wiseco inverted dome pistons, port & polished heads and intake, custom grind Comp 426 cam, Polished T-Trim Vortech supercharger, Kooks Longtube headers with flowmaster exhaust, CPR Fuel rails, Walbro 255 fuel pump, MSD Ignition, ARP mains and studs, ATI Balancer, DSS 1000 HP ½ Shafts, LSD, custom Vaca Performance Tune, KW coilovers, Hotkich sway bars, Asanti 3-piece AF-403, polished and anodized engine bay, RK Sport Heritage wing, Alpine and JL audio system, AAC Oracle Demon Eye headlights, tails, and HID Conversion
    www.projectsrt.com
    fnkychkn's Avatar
    greasy cardboard box
    remote start on this vehicle? i have seen some aftermarket remote start systems bleed voltage on the fused ignition switch output start circuit. while engine is running, backprobe PCM C1-30. there should be no voltage.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Nope, sorry Mr funk, it's most likely the tune (kinda of a standard issue deal). If you can go back to stock, try that out first. Oops, just noticed who tuned ya, yup, it's the tune. Have Josh check it out.
    fnkychkn's Avatar
    can't they make a tune that'll keep the cruise working?
    metgo's Avatar
    metgo is offline Life is too short to be driving slow
    St. Louis
    It has something thing to do with some torque converter feature they have in the CMR software.
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
    dgreekman's Avatar
    Guess i'll try and remove the tune and put the PCM back to stock and see.
    www.projectsrt.com
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by dgreekman View Post
    I don't suggest you do that. It's not like you gots yourself a stock motor.
    Boggus's Avatar
    Boggus is online now The HEMI pit
    Big Ole TEXAS
    Its in the tune ... the ole' verter trick - makes it lock up sooner but you loose the cruise control.
