Leak found
Well this morning when I looked under the car I found quite a bit of a mess on the cardboard I left under the engine. So after I jacked it up and crawled under I discovered that it was leaking from the underside of the thermostat housing... Popped the hood and checked the bolts, they were tight so I figured it was probably the seal. I followed the tip using the gallon baggie to catch the fluid which worked great. Removed the housing and when I pried up on the thermostat the seal just ripped. Probably the original and a bit fragile. Ran down to napa picked up a new thermostat with the seal got back to the car and finished it up. Ran it around town today and so far no problems, but we'll see in the morning...
donovan
Cool Vanilla 2005 Magnum R/T
