Ok so I was under the impression that the contiseals could seal up like an 1/8th inch hole, but I pulled a little 1/2 inch long screw that was real skinny and I go out the next day and flat, so I fiqure it was because I didn't run the tire after pulling it out so I air it up go do some running around, out all day, no light on evic so I fiqure I am good, go out again this morning and it wasn't all the way flat again but was below 20lbs. So I aired it up again and run on it today, so Is this normal, I fiqure I can't just take it anywhere for repair and can they even be repaired if necessary?
2010 LX&Beyond Nat'ls Best In Show Magnum Daily Driver
