Relax... no one to my knowledge has had any problems with the stock motor. The spring problems you have been reading about are all on modified engines, with aftermarket cams, none of these combinations has been through the extreme testing that the stock engines have gone through in order to satisfy emissions etc.
If you mod the hemi, it is no different that any other motor that gets modded... in order to reap more H.P. out of it, you are going to push parts and if you push hard enough, you are eventually going to break something.
Don
