Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    CplDaugherty's Avatar
    CplDaugherty is offline Once a Corporal... Still a MARINE.
    Dec 2006
    Back in Indiana
    Cluster Issues... becoming more frequent.
    2006 300C, no options, base radio for the C package (BA system, singe disc).
    I've noticed for a while now my "indiglo" gauges slightly flicker all the time... including the clock in the center console, while driving, during idle, etc... I figured its just the way our cars are, but now I'm starting to wonder.
    About a 9 months ago I was driving down the highway and I heard a "DING" and then the needles for the speedo and tach dove down to zero and as soon as they hit rebounded back to where they were. I lost no power, had no hesitation, the radio didn't stop (that I noticed). I figured it was just one of our gremlins... checked for a code... nothing. Key dance and Predator came up empty.
    About 3 months ago it happened again. Again while cruising at about 70. No codes, no loss of engine power or radio.
    Today it does it on my way home from work, this time while accelerating from a light. "DING" and the needles dive and rebound immediately. No loss of engine power or radio. About 5 miles later it does it again, but I notice a bunch of the idiot lights down where the ESP/Airbag/etc lights are flash... it was too fast to tell which ones lit up. This was while I was cruising at about 50. No loss of engine power, or radio. Checked it when I got home, no codes again.
    I'm thinking maybe my EVIC is starting to go out... it's one of the few things I haven't had apart, lol. I was just wondering if anyone had any ideas or had experienced the same thing.
    Thanks.
    If you can read this, thank a Teacher.
    If you can read this in English, thank a MARINE.
    Sponsored by Billet Technology
    Powered by Franks Racing Inc
    New build: 392 stroker, FRI street/strip heads, FRI cam, Kooks Longtubes, PI 3400 TC, SLP LM2 catback, LMI CAI, 09 Intake, CTP port matched spacers and DS loop, MTCM, Ported TB, BCR Coilovers, R1 rotors, Autometer AFR and fuel pressure gauge, Motorad 176* tstat, SRT wheels, carputer.
    [06 300C - 70 Mach1 347 stroker - 77 F250 460 - 85 Ramcharger 318]
    "I spent a lot of my money on booze, women and fast cars. The rest I just squandered."
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    Quote Originally Posted by CplDaugherty View Post
    Well then, my guess is that it's the one thing that's still working properly.
    Nah, I dunno man. I'll be watching though.
    Dec 2006
    Back in Indiana
    Hahaha thanks Mike.
    Now that I think about it, I don't remember if the flickering started before or after I hit that deer (body damage nothing serious). I was told they had to order a new harness for my front end because mine was damaged... maybe I need to pull the front end off and have a look. I know for a fact that I didn't have the gauge problem until after the accident.
    Dec 2006
    Back in Indiana
    Bump... anyone seen/heard of this before?
    CJ7VFR's Avatar
    CJ7VFR is offline Jim
    New Jersey
    There was a time early on in the 2005 and 2006 models where some of the fuses
    were not installed completely in the fuse boxes, and people were having trouble with
    their lights flickering from time to time.
    The remedy for this was to open the fuse box in the engine bay, and the one in the
    trunk, and push all the fuses down to ensure they all were mated fully.
    I know on my 2005 300C there were about 10 of them that were not pushed down
    all the way because when I pushed on them, I could feel them snap down.
    I can't remember if the fuses for the lights are in the fuse box in the engine bay, or
    the trunk, but I pushed all of them down in both places when I did it.
    Jim
    Drive to survive...
    Dec 2006
    Back in Indiana
    I'll give that a shot... thanks!
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    Chris - dude - I've had the SAME issue. Started about 2 months ago! Let's chat.
    Dec 2006
    Back in Indiana
    Doug I'll try to get on tonight and discuss.
    BTW happed again today, the needles were whipping back and forth for about 2 seconds and the radio cut off... I'm going to reseat all the fuses tonight. This was by far the worst it's ever done.
    wbglider's Avatar
    wbglider is offline Built SRT
    Everett Wa.
    Hope this works for you Chris, let us know if re-seating the fuses is the solution.
    timbur is offline timbur
    Jun 2010
    Milton ON
    I've also had the pulsating lights issue, was told it was a low battery, changed it and it almost went away. Now my tach has totally shut down, but all the other gauges are working fine, tried the cluster reset and all work but the tach. Does the tach have its own fuse?
    SoCal Gixxer's Avatar
    SoCal Gixxer is offline adrenaline junkie
    Sep 2008
    Huntington Beach
    Quote Originally Posted by timbur View Post
    sorry, but most likely, you have some sort of cluster internal failure, no fuse just for the tach
    Mod List in order of intstallation:
    window tint, magnaflow catback, airaid cai, srt shocks and springs, srt wheels, AAC interior LED Kit, 180 Tstat, predator 93 oct cai tune, srt sways, jba shorties, and sidewinder cam.
    316 HP/358 FT LBS *before cam*
    best 0-60: 5.58*before cam*
    338 HP/366 FT LBS *after cam*
    best 0-60: 5.33 *after cam*
    Afterhours Mopar Performance's Avatar
    Afterhours Mopar Performance is offline Formally & still NYINSTALLER
    Jan 2008
    South FLorida
    however front end crash equals issue with the brain of the car the fcm or the fuse box assemble. actually the fcm is the grey box attached to the fuse box. it can be removed by three tabs then check underneath it and make sure all the wire connections are tight and that the actual grey box is pressed against the fuse box tight.
    the grey box holds on by 4 screws but it has a multi pin connection on it. just press on the box via the corners to verify it is seated properly. that grey box is the brains of the opperation.
    the grey box itself also has 2 wire connections on it. press on them make sure they are tights.
    either that maybe when they replaced or repaired your harness something was not clipped in all the way or the soldering job was not done good depends on how it was repaired,
    Licensed and Insured.
    inertia cam. builder bill valve body, kooks headers. ported manifold/ Tb, johan email tune.
    *NYINSTALLER*
    9/10/10
    r/t- .317 60'- 1.594 1/4- 12.902
    bradenton. 10-9-10
    r/t .395 60'- 1.802 1/4 -12.890
    Facebook: http://www.facebook.com/pages/AfterH...348401?sk=wall
    Tranmission valve body, torque converters. and blue top installs.
    contact me for all your upgrading needs.
    Jun 2010
    Milton ON
    All fuses and fcm seated ok, still no tach?
    Jan 2008
    South FLorida
    well tach is thru the can bus network but generated by the ecm so check thos wire connections etc.
    *NYINSTALLER*
    9/10/10
    bradenton. 10-9-10
    Jan 2008
    South FLorida
    ecm is located and attached to the strut tower brace on the passenger side of the car.
    *NYINSTALLER*
    9/10/10
    bradenton. 10-9-10
