"Cheap fix???" for heater not coming on fast enough
Well there have been some complaints and I was right there on the bandwagon that the Dual Climate control does NOT heat the car up fast enough in cold weather if left on Automatic Settings ... Works great in summer for A/C but in winter the heat comes on very gradually and the fan never seems to go High Speed ...
Welll, I've been playing around with mine and believe it or not, the solution to fixing mine was so simple I'm almost embarrassed to post it after having lived with it being less than great for so long ...
I always kept both Temp Setting knobs on 72 degrees both summer and winter ... in 100 degree TX heat that would get the A/C to blowin' yer hat clean off as soon as you start the car. But at 40 degrees and colder the heater was anemic ... until last week ....
I turned both Temp Controls to 75 degrees ... Fan is set to Automatic, Vent Control is still set to Automatic .... we have HEAT!!! Gobs of heat!!! The fan comes on High as soon as the car gets the temp up to about 140-150 degrees and it actually gets HOT in the car ... now it just won't STOP!!! LOL ... I have to turn the Temp Setting back to 72 degrees after a while because it get's too warm ... I don't know why it's screwy like this, but at least I get all the heat I can stand now without having to play around with a bunch of controls ...
I hope the others who had the same complaint will try this out and let me know if it works for you too...
