I just got done changing out my rear diff oil. I used Mobil 1 synthetic 75w140. My Magnum only had 17,945 but according to the 2008 owner's manual you are supposed to check your diff oil at 18,000. I figured if I'm going to go through all the trouble of buying a 14mm hex bit, lift it and open up the fill plug I might as well take it one step further and just change out all the oil while I'm under there.
I didn't have any problem. Easy job. I drove the rear up on ramps and then put the front up an jack stands. I put a level under the car and it was perfect. I don't know how I did it. I guess I just lucked out.
I drained it and then I blew some compressed air in the fill hole. A lot more old oil came out the drain hole. I highly recommend this procedure with clean compressed air from an air compressor (canned air probably won't do anything). The old oil looked pretty good BTW. I guess 17,945 miles is probably too soon to change it but oh well.
I ended up using my oil transfer pump to get the fresh oil back in. I filled it until oil came back out and then quickly put the fill plug back in.
I didn't end up using any teflon tape as some have recommended. There wasn't any teflon tape on there from the factory so I figured it would be fine without it. No leaks so far. I tightened it to 37 ft/lbs.
When I first removed the fill plug it started dripping diff oil pretty good. I don't know how they fill it at the factory but it seemed a little high.
