U0125–LOST COMMUNICATION WITH DYNAMICS SENSOR- When Monitored: With the ignition on.
- Set Condition: If the Anti-Lock Brakes Module fails to receive bus messages from the Dynamics Sensor.
Possible Causes
WIRING HARNESS, TERMINAL, CONNECTOR DAMAGE
(D52) DYNAMICS SENSOR HIGH DATA LINK CIRCUIT SHORTED TO GROUND, SHORTED TO VOLTAGE, OR OPEN
(D51) DYNAMICS SENSOR LOW DATA LINK CIRCUIT SHORTED TO GROUND, SHORTED TO VOLTAGE, OR OPEN
DYNAMICS SENSOR
ANTI-LOCK BRAKES MODULE
do you have some sort of ESP disable mod tapped into the dynamics sensor wiring?
