What would the latest version be for a 2005 Magnum?
Thanks in advance.
Thanks in advance.
04839559AL is the latest part number for the software in the CCN. Not sure what version this will show on the evic display but I can go look if needed. This is the software that is currently loaded into my Magnum.
2005 Dodge Magnum R/T
-Martin Luther King, Jr.
Just checked. 3.61 dated 7/27/04
I have 3.60
2005 Magnum they say its the most up to date version for my car. does 2005 build date have different ccn #s
or different equiptment define the ccn#
If they searched by your vin then it would not show up as needing an update. The newer software only shows up when you search by Year Model and Engine. They will not flash the new software for you unless it addresses a particular problem.
I was sure there was a newer version.
My problem, and others have noted it as well, is that whenever the temperature is below 0 and you go into the extended evic display, the oil pressure display gets corrupted and the speed starts indicating -kmh's.
Annoying!
I thought I read about a TSB on the display...Originally Posted by mr.niftie
Don
