Results 1 to 15 of 15
    modesto83's Avatar
    modesto83 is offline USF Engineering
    Tampa
    Car Over Heating!!! Help!
    Well I just replaced the water pump, and thermostat, and my car is still over heating.
    I thought it was the water pump or thermostat so I replaced both.
    After I replaced both water pump and thermostat I took her for a drive and after about less than 10 min driving about 45mph the needle started climbing and I shut her off just right before it got to the red line.
    Any suggestions on what it could be?
    I flushed the radiator fluid and purchased new fluid from Dodge. Cost me 23.00 for the gallon because I know our enginges takes special radiator fluid.
    Please guy help me out.
    Black Charger SRT8 on 24"x10" wheels, lambo doors, hid head light & fog lights, led interior/blinker/license plate/.
    tank8289 is offline Supporting Vendor
    Jun 2007
    West Milford, NJ
    Maybe some air in the system after the new install?
    392 Stroker, Builder Bill TC, Builder Bill tranny, LXAS LVLI Tcase, Novi 1500 10.5psi, 150 shot of nitrous, tuned by Josh @ HHP
    rg-300c's Avatar
    rg-300c is offline <---- Last known Kuldip sighting
    BC Canada
    Silly question but are the fans working
    modesto83's Avatar
    Tampa
    yeah the fans are running, its over heating eaven while I am crusing at 45 mph.
    I was thining air in the system, so when I got home and parked it I let it cool a lil and loosened the radiator cap to let the air pressure out.
    Any other suggestions?
    Had my Charger for a lil over 2 years and this sucks
    PowerWagon896's Avatar
    PowerWagon896 is online now Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    Are the fans coming on?
    Do the 25-cent fan mod W/all three relays jumped out.
    (Bottom picture in this post)
    http://lxforums.com/board/showpost.p...34&postcount=3
    You should here both fans running on high speed.
    If the fans don't come on, check the fuse, etc.
    If the fans do come on, drive it & see if there is any difference. in coolant temperatures.
    If that cures the problem look into your fan controls.
    45 MPH might not be enough to keep air moving through the radiator if the ambient temperatures are high.
    If there is no change, the problem lies elsewhere.
    May 2006
    Quote Originally Posted by modesto83 View Post
    OK the fans are working.
    I would remove the TSTAT & use a funnel to fill the block slowly untill it runs over @ the TSTAT housing. That will get most of the air out of the block.
    Start it up & let it idle while monitering the coolant temperature & the collant level in the tank.
    Also, moke sure the fans are running in high speed mode when the coolant tempetures got above normal.
    After a good "burp" it should stabilaze.
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    The worst case scenario could be a head gasket. If all else fails, check the not so obvious.
    moparcarguy is offline LX Padiwan
    Apr 2009
    albany ny
    are you sure the guage is working properly? bad sending unit?
    MoPOWeR-349's Avatar
    MoPOWeR-349 is online now Whiskey Tango Foxtrot: Buster Buster
    Nor Cal
    I've seen this more than once...check your inlet and return hoses from the radiator, sometime they collapse and restrict flow.
    Mag05's Avatar
    Mag05 is offline The HEMI that roars
    Jun 2008
    Brantford, On. Canada
    Only a few suggestions, are you getting heat in the car, feel both rad hoses for temp. if you have a digital temp. meter, check all over the engine and all around the rad,[don't use your hands], maybe pull the tstat and test it in boiling water to make sure it is opening, could still have air. Let us know how the rad hoses feel after running and normal temp reading[idling], don't let the reading get to the red line too often
    SLP CAI, SLP Catback, SLP 25% underdrive pulley, 170 stat, Predator SLP tunes[2], Mopar TCM, no esp mod.
    slideway's Avatar
    slideway is offline Onward, through the fog
    Jun 2007
    Union co. N.J.
    There's a 1/4" pipe plug at the top of the water pump to bleed the air out of the system when you change coolant or water pump. loosen/remove plug and let air escape when t-stat open's, when coolent flow's out replace plug. (with some teflon tape on it) coolant system should burb out all air now.
    May 2006
    Quote Originally Posted by slideway View Post
    Good luck geting it out ifthe car's several years old.
    Mine won't budge.
    This is the best way if the plug comes out. Removing the housing & using the funnel to get the coolant into the block will accomplish the same thing if the plug won't come out.
    FL3JM's Avatar
    FL3JM is offline Mopar fan from Sweden :)
    Feb 2006
    Stockholm, Sweden
    Quote Originally Posted by richierevs View Post
    Head gasket? If it leaks into the combustion chambers there should be white smoke coming from the exhaust.
    I have a hard time believing that its the head gasket.
    clevye25 is offline LX Padiwan
    Dec 2009
    bump..
    old i know but im experiencing the same thing after replacing my water pump
    any advice on this..
    R/T Road/Track, 35% window tint, Hotchkis Sway bars, Eibach Pro-Kit Replaced by KW Coilovers V2, Custom Black Grill, halo headlights, K/N CAI, Dynatech headers, 22x9 ace rims, Pirelli pzeros 265/30/22 and 265/35/22, no cats, flowmaster 40 series exhaust and a leaky water pump
    smagnumrt's Avatar
    smagnumrt is offline LX Padiwan
    Sep 2009
    Winnipeg, MB
    Run it with the cap off and keep it topped up and have the heat on in the car. Its most likely air in the system just run it til it clears
