Results 1 to 15 of 20
    Fondy's Avatar
    Fondy is offline YUUUUUUUUUUUUUUUUUUP!
    Feb 2006
    Fond Du Lac, Wi. Member# 5136
    Exclamation In car headreat cam!!
    here is a couple videos of my in car camara mount that i made a while back the first is my first run. took it up to about 100 and backed off. looked at the video and the realized i needed it to be higher so you could see the road.
    after i raised it it bounces a little need to fix that. but i made it myself so its not 100% done.
    Click here to see Video
    :insert sig here
    pigpen's Avatar
    Minnesota
    how did you make that? or where did you buy it at
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Looks like a good time! Nice vid and thanks for posting.
    John Y
    Fondy's Avatar
    Feb 2006
    ok here is my mount so you can see what i did and make it better! LOL
    first try what i used in first video
    second try what i used in second video
    and a close up showing the bolt that holds camara and how i tip the angle of the camara
    hope the pics help
    :insert sig here
    bipto's Avatar
    bipto is offline Daytona 500 bound!
    New Hampshire
    Cool stuff man! How big / heavy is your camera..?
    The Iron Mistress Galleries
    R.I.P. Dave...
    Fondy's Avatar
    Feb 2006
    well so far all i have put on it is my sony cybershot that is a still camara that can take video. have not tryed a real video cam. it would hold it im sure but with the angle brackets i have in the middle it makes the mount a little weak.
    :insert sig here
    BUTWEET's Avatar
    BUTWEET is offline GOOD MEAT TAKES A LONG TIME!
    Bothell, WA
    Very ingenious. One question! How did you get a Magnum with a manual transmission?
    MY MEAT WILL MELT IN YOUR MOUTH....NOT IN YOUR HANDS! ENJOY THE Q.
    Jaak's Avatar
    May 2005
    Take the dangly crap off the mirror for the final vids!
    Few thoughts come to mind, looking at that.
    1) If you have to slam on the brakes that camera is going to swing around and smack you in the head.
    2) If you did a mount that was supported from the passenger seat as well, it would be more stable.
    3) Particle board cut like that, might decide to fall apart under load.
    Cool idea... I might try something like that but use some old hockey stick handles. Bit stronger than particle board!
    2006 Magnum SRT8 - 11.85@117
    bigjim's Avatar
    bigjim is offline Damn Fast Grandpa!!
    Oct 2004
    LaFargeville, NY / Bolton, ON
    Quote Originally Posted by I'M BUTWEET DAMMIT
    He shifts the same way I do most of the time, if you use the auto stick ALL the time you will get the hang of lifting a little bit when you shift. The advantages of this are quicker shifts because the computer doesn't wind you back bacause you have already done it and much better transmission life as there is no torque on it when it shifts. Learn to do it with light throttle pressure first then gradually increase it, noone will be able to tell if it is an auto or a manual.
    Jim
    05 Magnum RT 5.7 (Member ALLPAR.com 200,000 mile club) Rockinsrt8 shifter, Hemi reg #164 266,666 miles (c'mon John, I slowed down! NOT)
    Sidewinder, 6.1 pushrods, springs, underdrive pulley, SRT exhaust (donated by NHDave) headers to tips, all installed by Hemi31! Quaife, certain Pedders bushes installed, SRT Nivomats and Bilsteins. Police rotors and pads. HIR. Predator. LMI.
    1:19 NJMP Lightning
    1:45 Mosport
    BUTWEET's Avatar
    Bothell, WA
    Thanks Bigjim. I'll have to practice that in the Charger.
    Quote Originally Posted by bigjim
    Jim
    grinner's Avatar
    grinner is offline ModdinArt.com
    Dec 2004
    stl
    nice man
    bring it on over to attach to the other headrest and ya won't have any camera bobble.
    Fondy's Avatar
    Feb 2006
    Quote Originally Posted by jaak
    yeah like i said i put this up to show you what i did so you can inprove on it and as far as the danglies they are gone i didnt want them in the first place but the wife put them up. then after started doing mods she took them down. so take my idea and run with it make it better.
    the first video i put it down in first and just let the computer shift. it works well.
    :insert sig here
    Fondy's Avatar
    Feb 2006
    Quote Originally Posted by grinner
    nice man
    thanks i think the next one i do is gona be a double headrest.
    :insert sig here
    Guest Guest
    I just hope the camera is running at the time. LOL
    Reppr's Avatar
    Reppr is offline join date 05/06/2004
    May 2004
    Gig Harbor, Wa
    Hey Weet, does your wife no you're gonna do power shifting in HER car and not the magnum? UUUHHMMM, I'm telling!!!!!
    Member #197!
    Ah, screw the diet.
