Results 1 to 15 of 17
    jasonr_01's Avatar
    jasonr_01 is offline I've got wood!
    Iowa
    Car Electrical Mishap!!!!!
    So today I get home from work leave the car running cause the wife and I are gonna go out, get back in the car shut all the doors and the door ajar light is lite. So I check all the doors and reliaze that I can't unlock or lock the doors with the door panel switches, so i manually do it everythings shut nice and tight still the light on. all the lights are on in the car the dash is lite up I can only look at the temp on the gauge cluster and can't rotate between trip, odometer and temp. so i try everything i can think of to fix it. and the only thing i came up with was a battery disconnect, which solved the problem.
    But my question is what happened, what did i do to make this occur. is something wrong??? there's no lights, no nothing... it acts now as if nothing is wrong. Please fellow lxer's fill me in with ur insight. i've only got 1000 left on the bumper to bumper warranty.
    Is there any computer part that could be messed up, or did i just do something to make this event occur and it was all pure fluke.
    The mod List is getting to the point that its just to long to post. So if you wanna know whats in it, just ask?
    crazy_luck's Avatar
    crazy_luck is offline I know where Hoffa is...
    Belle Plaine, MN
    It might be a possible door switch issue, it'd be the first one I've heard of, but it seems like one of the more likely possibilities.
    grinner's Avatar
    grinner is offline ModdinArt.com
    Dec 2004
    stl
    just a hickup A ghost in the machine. Computers have glitches. I use to freak everytime my car did somthing weird, like vroom suddenly at a redlight, almost rear ending the car in front of me (I now hold the break harder), or doing nothing but spinning rpms sometimes when I put it in gear, or the back drivers window working sometimes and not others, or the remote not working then being all happy. I know the switch in that back left wondow needs to be replaced but the rest is just chalked up to an early version of a computer that will be revised many many times.
    moparman53's Avatar
    moparman53 is offline Finally got a HEMI again.
    Nov 2004
    E Williamson Co, Central Texas
    I wouldn't worry about it unless it keeps happening.
    MAGNUM8R's Avatar
    MAGNUM8R is offline Yes I am a pirate, 200 years too late
    So. California
    'Jus shut 'er down and start over.
    Hal is playing with you!!
    An over 40 victim of fate.
    '8R'05 Magnum RT Midnight Blue Pearl
    KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
    Hi Flo Cats
    graymagnum's Avatar
    graymagnum is offline GRAYMAGNUM
    May 2005
    OLYMPIA, WA
    '05 mag 5k miles
    started my mag today, no turn signels,no dig readout,no winsheld wipers, no hi beam------only changes on car--cat back and k/n----only possable factor, not driver for 2weeks---HELP! how do i clear the p/c /?--
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by jasonr_01 View Post
    did this happen on the magnum or the 300? year, model and engine would be helpful.
    does it have auto up windows on both front doors?
    i know these questions may seem strange but there is method to my madness.
    jasonr_01's Avatar
    Iowa
    05 magnum se 2.7l
    it only has auto windows on the driverside front only.
    jasonr_01's Avatar
    Iowa
    well wait not auto up windows, only auto down after one second on driver front.
    fnkychkn's Avatar
    doubt it's something you did. sounds like the CCN/cluster may have lost one of it's power sources or locked up somehow. since you're still under warranty, i'd get the dealer to look at it. even if they don't find anything, at least it will be documented. you disconnecting the battery, although it seems to have cured it, will also have erased any possible DTCs so don't be surprised if they can't find a solution. you might also want to check that all fuses (front and rear) are fully inserted.
    jasonr_01's Avatar
    Iowa
    will do, ya i thought of that, well not to unhook the battery. but the lights wouldn't shut off and i knew if i didn't the battery would be dead for sure in the morning.
    jasonr_01's Avatar
    Iowa
    also thanks for the input.... man i'm a real post whore tonight...
    Cdn_Magnum's Avatar
    Cdn_Magnum is offline LX Guru
    Jun 2005
    KW, Ontario , Canada
    Did you get a static shock getting out of the car??? A static zap could cause a hiccup like that... i know with the weather right now i get one getting out of the car and the radio is effected by it. There is a TSB for static straps on the seat frame rails,
    Russ
    - Falken 20" Explict Black rim,Falken 255 45 20 tires,8"LCD monitor headrests,12" LCD monitor in custom tri fold in back,custom made CIA,Infinity engine cover w/custom paint,custom painted centre bezel & console,custom lit cup holders, LED interior lighting & grill lites,HID's,300w sub amp w/custom enclosures,custom hand-made mesh grill
    jasonr_01's Avatar
    Iowa
    Had the samething happen again today, checked the error codes and pulled a code 481 which is Cooling fan relay 2 control circuit.
    What would this have to do with whats happening and where is this relay located? If so I might just try getting another relay and just putting one in, if this is the case.
    fnkychkn's Avatar
    did you look into installing a ground strap on the seat frame like Cdn_Magnum suggested? TSB 08-049-06
