Looking for info on the right cam for me.. Where do I start? I know very little about cams and what all needs to be done for the upgrade
07 300C - AFE Stage II, SLP Loudmouth I
06 Speed6 GT - Cobb AP Stage 2 (Dizzy Tuned), M2 DP w/ HF Cat, Magnaflow CBE, AEM SRI, KMD Internals, TurboSmart BPV, SU RMM, Denso ITV22
You can start by figuring out what your goals are. How much power are you looking to build? Are you planning to stay naturally aspirated or do you plan to supercharge/turbocharge? Are you planning to change your torque converter? Do you want to keep MDS? Do you want more streetable torque or upper-RPM horsepower?
There are a ton of great people on here that can and will help once you specify what your goals are.
2005 300C Magnesium Pearlcoat
BBK 85mm TB, Volant CAI w/lower duct,
2006 TCM swap
DS Predator 91 CAI canned tune
180* t-stat
Borla cat-back 140112
SRT struts/springs + Hotchkis sways
^^Good Points^^^
Give us a call we will be glad to help you get what you need
Chris 276-663-1555
Dave 276-666-1934
www.ModernMusclePerformance.com
www.HemiSwapShop.com
www.ParamountPerformanceShop.com
The sky is the limit. Or maybe I should say the stock 5.7 cast exhaust manifold is the limit.
Replace that with a SRT exh. manifold, mids, and get that connected to your SLP, and you'll have room to breath.
Without that, and for a mild streetable build that boosts 30+HP the Sidewinder can't be beat. HHP Bessmer Comp 260 functions well also, and will run on the stock PCM flash. It likes a custom tune for a few more HP.
So maybe start with a DS tuner that's needed to support the cam.
The stock 5.7 heads breath pretty well without any modification, but changing all valve springs to 6.1 exhaust springs.
All that's left is the restriction of the stock 5.7 intake manifold for 6K RPM and above. Eagle and 6.1 are adaptable.
I've blown well over 15K on a stroker, tranny, rear end and half shaft mods to hold it all together.
Honestly, if I had a re-do - I'd have just done the exhaust from manifold to tips, and a Sidewinder. That really wakes the car up. That will put you close to SRT power. The speed limit is still 65.
Just a grocery getter!
^^^^^ I agree and will add that Inertia's Super Spartan is a pretty badass cam in it's own right as well (you just need SRT valvesprings and 6.1 pushrods) and you're all set. Should get you 30+ RWHP/TQ.
I will never explain myself to a man who rises and sleeps under the blanket of freedom that I provide, then questions the manner in which I provide it.
GRUNT: Term of affection used to denote that camouflaged, filthy, sweaty, dirt encrusted, foot sore, ripped trouser'd, tired, sleepy, beautiful son of a bitch, who has kept the wolf away from the door for over 200 years.
Speed cost money... how fast ya wanna go? I 2nd Inertia's cams... I got a SRT Max on order for my 6.1L
SRT Max cam, SLP 25% UD Pulley, Jet 180 T-Stat, Solo X-3 catback, 3.73 Getrag, LMI fenderwell CAI, and Zeitronix ZT-2 AFR.
Cam install by Troy Ding w/ tuning via Johan. Dyno 31Aug2012: 414hp/410tq _Idle Video_ Best 1/4 mile: 12.571 @ 110.7 mph
All Mods listed at --> 6.1L Hemi Registry #1530 10ChallSRT8
Thanks guys. Thats what i was looking for so now i use that fancy search bar to read up on everything. Now i gotta look for a shop in IL to do the install and custom tune.
No money for blower or turbo. But still looking for breathing room between my friends headlights and my. Tailights
Inertia Motor Sports has Great Cams, Give Stu a call
When I did my cam install, I pulled the fascia, dropped the radiator, and pulled the heads. It's pretty simple at that point. You do need new primary head bolts, and it's a great time to put on SRT or shorty headers while you're at it.
Check around the forum and local area for roving LX mechanics.
Eibach Pro-kit springs,dampeners, and sway bars,BWoody front sway links, K&N Intake, Predator tune by Stu, 180 T-stat, BT park lock replacement and catch can, Pedders tension strut bushings & bump-steer kit, Blastin' Bob's 4db resonator kit, Inertia Super Spartan cam,6.1 springs & pushrods,JBA shorties, 6.1 pulley, '08 Charger 18's with 235/55/18 Toyo Versados front, 255/5518 Yokohama YK580's rear, R1 Concepts premium front rotors, PosiQuiet pads
2013 CHALLENGER SRT8 AUTO IN BLACK
LMI TRUE CAI
MOPAR LOWERING SPRINGS
BLASTIN BOBS AXLE BACK W/ RESONATORS
MAGNAFLOW MID W/ HIGH FLOW CATS
3.73 GETRAG LSD
EDGE 3400 STALL CONVERTER
SPEEDLOGIX REAR SEAT DELETE
......MORE TO COME....
Don't know about shops down in Bloomington, up here around Chicago is Mr Norms and Modern Muscle. Justin at Modern Muscle can do a nice custom grind for you. Good luck with your mods
ProCharger, CMR Tune by Johan, Ported TB, Corsa Exhaust, Jet 180 T-stat, Blue LED Interior lights, E&G Bentley Grill, Ipod Adapter, SRT8 Billet Pedals, Lambo Doors, Cherry Wood Dash, CA Classic Strut Brace, ProTorque 2800 TC, Chrome Valve covers from 3G and Polished firewall
Does modern muscle do custom tunes?
