Results 1 to 5 of 5
    GoofyGuy's Avatar
    GoofyGuy is offline Turbo Innovator.
    Springhill FL
    A/C system surge?
    Well I didnt know what to call it but I will still expain to see if you guys have similar problems? If you have been keeping track this is problem 4 with my R/T. If the A/C is on in any setting when its on a/c setting on it will blow cold quick but theres still and issue. It will got Hot for a second or two every few minutes. With a digital thermo in hand a friend and I went on a ride and sure enough its 66 at the vent then jumps to 89 for 3 seconds at a time. Its random in time. Anyone else?
    l1tech is offline LX Padiwan
    Jan 2005
    Does the temp go directly from 66 to 89 or does it slowly climb to 89 and hang there for a few seconds and then slowly climb back down??? Also do you have climate control?
    GoofyGuy's Avatar
    Springhill FL
    Quote Originally Posted by l1tech
    no I dont have climate control. it jumps real fast then back down. It takes maybe 3 seconds to jump to 89 and that could be the refresh of my thermo. And it goes back to super cold instantly.
    Jan 2005
    For it to make that quick of a change there would have to be a temperature blend door opening and closing suddenly for no reason, the ac just turning on and off would not be able to change temps so rapidly.
    GoofyGuy's Avatar
    Springhill FL
    on a ride today I can hear and feel the a/c comp turning on and off for some reason. I wonder if the swich is going to high heat for a breif moment for some reason. This will be the last straw on my back. Any little thing and the dealer can have it back.
