Results 1 to 8 of 8
    Hemi_RT_AWD is offline LX Padiwan
    Jan 2005
    State College, PA
    Bumpy ride revisited
    I was driving home yesterday during a long trip and was messing around trying to figure out my ride vibration problem. I tried holding the brakes lightly with the gas to see if that made things worse, tried coasting vs. under throttle, etc. I am getting road vibrations that used to only start around 65 mph but yesterday I could feel them as low as 40 mph. With any luck that means whatever is causing the trouble is getting worse and might be possible to find now! Anyway, I thought I remembered that the AWD cars came with the load-leveling shocks and I began wondering if those went bad if they would cause a rough ride that could be felt in the seat? Am I right about the AWD having Nivomats stock?
    FOHN_JARGO's Avatar
    FOHN_JARGO is offline Ka CHOW!
    Bella Vista Arkansas
    Not sure about the shocks but it seems plausable.
    Check your tire sidewalls for bulging. You could even have a stealbelt seperating.
    The Magnum has a soul. It has a personality, something all too lacking in the automotive transportation appliances everybody else is offering.
    Jan 2005
    State College, PA
    I'm planning on adding some weight to one wheel at a time to see what that type of imbalance feels like to try to rule out the tires.
    Dr Teeth's Avatar
    Dr Teeth is offline LX Guru
    Nov 2006
    Calgary, Alberta, Canada
    Nivomats were an option on AWDs, not standard. Not sure how you check to see if you have them or not, but a dealer should be able to tell you from your VIN.
    2006 300 SRT8. Black. Razors Edge Shock Tower Brace, Diablo Predator, Torque Thrust M's, Nito Invos, BT catch can.
    Robins_SXT's Avatar
    Robins_SXT is offline LX Padiwan
    Nov 2004
    Warner Robins, GA
    The bottom end of Nivomats looks like a metal bar about 1" diameter whereas the regular shocks are about 2.5" diameter on the bottom.
    MikeEast's Avatar
    Ducktown, Georgia
    I had a vibration that drove me nuts on a Taurus Wagon, that turned out to be the rear motor mount. Felt it most at my feet and some in the seat. The Ford dealers were perplexed, after all when you complain of a vibration, it can't be anything but tires, right?
    Have your tires ever been dismounted? Are these the stockers? Had a 80 Buick Skylark that had a quart of water in each tire that was a real bitch to figure out too. That one was perfect up to about 40 or so and ONLY on smooth roads would you feel the shake start when going faster than that.
    This is where an AWD dyno would be cool - run it at speed where you can watch it.
    Mike
    Hemi Mag's Avatar
    Hemi Mag is offline Baba Booey
    Nov 2006
    Mississauga
    could be a couple of things, tires being teh obvious one. Tire rotating them to see if the vbration changes from the seat to teh steering wheel. A common problem that Neons had were bad control arm bushings, and they would present symptoms in a similiar fashion. It could also be a bad half shaft.
    AC
    http://www.lxforums.com/board/signaturepics/sigpic12069_2.gif
    'When I was arrested I was dressed in black'
    _____________________________________
    Mods: Predator 93 CAI, Air Hammer, Eagle Mani, Stainless Works Long Tubes, JBA Catback, SRT8 suspension, Mopar Sways, REM Strut tower bar and Bumpsteer, Dual weave Grill, Daytona Chin and 20s, CSRT8 Diffuser, Kicker Sub, 6000K & 3500K HIDs, shaved letters, Old skool R/Ts, Hood Struts, 300C Handles & lower moldings, Two toned tails, BT Oil Catch and other goodies, Husky Liners, and Sirius Stilleto.
    13.5@105
    Electrofreak's Avatar
    Electrofreak is offline Can't shake the shock!
    Rochester, NY
    Also check and make sure you don't have any ice frozen in your rims!
    I've parked in a deep puddle before that froze, then drove off with some nasty vibration! I had to take both tires on one side off and knock the ice out of them to get it runnin' smooth again.
    2005 Inferno Red Magnum R/T AWD
    Electronics Group, Convenience Group II, Protection Group, Roof Rack package (removed cross bars), Sunroof.
    Mods: Superchips, tinted windows, painted calipers, auto headlights, blinker mod, air silencer and lower radiator baffle delete.
