Bigjim, Not sure I understand the first part of your post...I think I do understand the purpose of brake bedding.
stoptech.com puts it better than I as: "...Simply stated, bed-in is the process of depositing an even layer of brake pad material, or transfer layer, on the rubbing surface of the rotor disc." and "...the objective of the bed-in process is to deposit an even layer of brake pad material, or
transfer layer , on the rubbing surface of the rotor disc..."
for more, see:
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
and
http://www.zeckhausen.com/bedding_in_brakes.htm
Am I missing something here?
As to comparison against another 300c, great advice, and I am happy to say I did the same thing with two 300c's (my neighbor and his father have a 2005 and a 2007).
While both exhibit what I would describe as "normal metallic sounds" during braking, which is identical to what I would describe from my
right front brake rotor/disk, both under light, moderate, and heavy braking application (that I would expect from metallic or semi-metallic pads), neither of theirs exhibit the high-pitch whine that I get from my left front brake/rotor/disk, only under about 1/3 braking application.
tbird, thank you very much.
I looked at the pads per your advice, and the shims are fairly pristine. Plenty of pad material left as well, and you were correct--no rust on the rotors.
Only 14K miles on the car, the rotors are as thick as Rosie O'Donnell's head, and I'd much rather spend money on a Diablo Predator than swap out brake pads and perhaps even rotors that are functionally perfect but just like to squeal like Ned Beatty on the left side only, and only when the proper recipe of "just the right pedal pressure, no more, no less + brakes already warm + precisely when it would be frustrating to me and potentially embarassing" exists.
But it sure seems to me that if it was a "well, this is just because you have metallic or semi-metallic brake pads" thing, that my 8 runs at 60 mph, 6 at 80 mph, then 4 at 100 mph (uh, um, on a closed course, Officer!) to make sure the pads were properly bedded in (unless you know otherwise, bigjim?), having the pads re-surfaced and the rotors turned by the dealer, and that I get the noise not "almost all the time" but only under specific pressure suggests it's something different?
And if so, are there any bullets to put in my "take it to Chrysler gun" that would allow me to get it resolved without it costing ME money I'd rather spend on more goodies?
(tbird, I guess I'm saying I don't think it's a brake-pad-to-rotor issue, per say, particularly because the shims look good--should I put the stop squeak on the backs of the pads anyway? If I say "screw it" and get higher-performance pads, would I have to bleed the brake fluid, or could I just swap the pads?)
Pete
