Results 1 to 12 of 12
    FloridaRT's Avatar
    Ocala, Florida :-)
    Unhappy Bosch Cooling Fan Relay / Wayek Inc.
    Looks like Waytek Inc. no longer carries the Bosch relay for doing the fan mod.
    OcalaHemi (Steve) found out that Waytek no longer lists the Bosch relay that was perfect for doing the fan mod. The relay had a part # 75114, which is no longer stocked. I did do some searching of their relays and found a relay (part # 75414) that might work, it is made by Taylor.
    Just wanted to give a heads up for those that might be doing the fan mod in the future.
    Later,
    Bob
    Jaak's Avatar
    May 2005
    If you are thinking the modified relay fan mod, I'd actually suggest getting the $75 manual version of the coolit mod from www.noesp.com
    That's $75 including shipping, and it works the same way, but without the hassle of finding the right relays then taking them apart and doing the mod yourself.
    In the long run, it's a deal...
    2006 Magnum SRT8 - 11.85@117
    FloridaRT's Avatar
    Ocala, Florida :-)
    I agree, I told Steve about Noesp, but he wanted to do the mod his way.
    I have the (JAAK) fan relay mod and like it, but if it ever acts up, I will go with the NoESP mod.
    Bob
    sdcarguy's Avatar
    sdcarguy is offline LX Padiwan
    San Diego
    Id just wait and buy a tuner that adjusts the fans for you...
    2006 Silver Srt-8 Option groups 1,2,3, air bags and sunroof, KWv2s, Hotchkis Sways, Bwoody end links, tinted tails,phenolic intake spacers,Magnflow High Flow Cats and Exhaust,170 T-stat HIDs low and fogs 5000k, USW Forged DLux 22x9.5 and 22x10.5 with Vredestein 265/35 295/30, Demon Eyes, Diablo Predator, Screwed by Techco.
    Jaak's Avatar
    May 2005
    I'm doing that too. But sometimes you want to turn them on manually. Like when the hood's up, the ignition's off and you're trying to get the heat soak out between runs!
    stitchmonkey's Avatar
    stitchmonkey is offline What's up Doc? Who's drivin this thing?
    Feb 2007
    It rubs the lotion on it's skin, or else it gets the hose again!
    I got the NoEsp/CoolIt mod auto version cost more but I love it its well worth it,
    OcalaHemi's Avatar
    OcalaHemi is offline LX Guru
    Ocala
    After looking at the NoESP/CoolIt setup there are several wires they want you to splice into. They have you pulling fuses and what looks like a black relay and connecting wires to them and then to the boards they send. I'm a bit worried about all that wiring. I'm not an electronic genius, and don't want to short out my wiring. Wanting something more simple. I don't drag race my car, just normal driving, but alot of Hwy driving and want to cool it down a bit. I found that Jaak's fan mod was easy to follow and after finding a relay at Pep Boys I was able to do the mod. I would still like to find the Bosch relay.
    300 (SRT) front, MSRT rear bumper, shaved rear wiper, 402 rear spoiler, RK/Sport raised hood, Grip grille, Boss 304 18" wheels, 245/55 BF Goodrich tires, painted coolant tank (402), painted engine cover and ABS cover, LED tail lights and side markers, LED lighting in engine bay, MagnaFlow High Flow Cats & exhaust, Vortech V-3 S/C, Vortech Predator tuned, 180 Tstat, X-treme Duty Radiator, Billet/Tech engine dress up, B/T oil catch can, Painted radiator cover! A big Thanks to Rod Burton who did the conversion & S/C install.
    OcalaHemi's Avatar
    Ocala
    I am going to have to move my probe down a little on the radiator, as I have not heard my fans come on with the probe. If I ground the wire to the probe the fans come on. The probe is set at 185 degrees. When I heat the probe with hot (boiling) it turns the fans on. So I guess it just isn't getting hot enough. My temp has been running 190-199 at the hottest point after doing the mod. I was running 217-225 before the mod.
    InferAl's Avatar
    InferAl is online now "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Quote Originally Posted by jaak View Post
    The only thing I hate is at night on the track when you put it on or off all the lights going on and off and the horn beeping. I wish it just had a on ans off switch
    Video
    bipto's Avatar
    New Hampshire
    Quote Originally Posted by InferAl View Post
    Ya, I've found that does tend to raise a few eyebrows...
    IIRC, for those who want to have their cake and eat it too (switched as well as automatic fan control using the Cool-It), it's as simple as switching the wire that runs between the two PC boards to ground. I haven't done it yet myself, but it's on the list. Trying to find that post as we speak...
    The Iron Mistress Galleries
    R.I.P. Dave...
    Jaak's Avatar
    May 2005
    Yeah, it works the same as the jaak fan mod in manual mode. That's why I like it.
    Feb 2007
    Quote Originally Posted by OcalaHemi View Post
    I'm no wireing genius either the iNCREDIBLE Mr iNCREDIBLE wired mine up. you just make sure the battery is disconnected for the initial and follow the instructions or if your a spaz like me have someone experienced do it
