Results 1 to 5 of 5
    05awdrt is offline LX Newbie
    Jun 2005
    Blank screen on radio
    The radio works, but there was no display. Adjusted the volume and the vol bar appeared. Turned it off then back on, and all is fine. This is the first time it did it. I have the 6-disk cd/nav. Should I look into getting the extended warranty?
    LtlDad's Avatar
    LtlDad is offline LX Padiwan
    Nov 2004
    OC, CA
    Like others have mentioned, try pressing the "INFO" button on upper right, that 'might' get your screen back.
    2005 Mineral Gray SXT
    HAS SOME STUFF...
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by 05awdrt View Post
    a radio flash might help that.
    bipto's Avatar
    New Hampshire
    I have had this happen twice in two years of owning my Mag - both times the screen was completely blank on startup, both times the only thing that would bring it back was a re-start, after which it was perfectly normal. Don't have any idea what causes this little "hiccup," but I do know that given the frequency of its occurence there's no way I could ever demonstrate this to a dealer...
    I'd say keep your eye open for it, but chances are you may not see it again for a while...
    The Iron Mistress Galleries
    R.I.P. Dave...
    Jun 2005
    Thanks for the info guys. This was the first time in 2+yrs that this happened. I hope that it doesn't go out for good. With nav and all =$$$.
    What does a radio flash do? Will the dealer do it if you ask, or do you have to show what it does first?
    Thanks again all.
