Results 1 to 7 of 7
Thread: Belt removal?
    xk49's Avatar
    xk49 is offline LX Padiwan
    Nov 2008
    USA
    Belt removal?
    The service manual says the following:
    Belt tension is not adjustable. Belt adjustment is main-
    tained by an automatic ( spring load ) belt tensioner.
    1. Disconnect negative battery cable from battery.
    2. Rotate belt tensioner (6) counterclockwise until it
    contacts it’s stop. Remove belt, then slowly rotate
    the tensioner into the freearm position.
    Do you grab the tensioner with your hand and and pull? I tried and it didn't budge. As a matter of fact, it looks like if a try to rotate that arm counter clockwise it looks like it would put more tension on the belt. Do have to loosen the bolt that holds it on first before rotating?
    "Just because that's the way it is, doesn't mean that's the way it should be."
    2007 MSRT8, FlowMasters 40's, Vortech V3 SC, Magnaflow Hi-flows cats, BC coilovers, Hotchkis F/R Sways, Razors Edge Strut Brace, DMH cutouts, Silver Box, BT Catch Can and Engine Bling
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    You use a 3/8 drive bar to move the tensioner.
    I said it before and I am going to say it again.........if you are not comfortable(familiar) working on these cars I would see if there is someone close to you willing to give you a hand......this is not exactly the type of thing you want to learn on.
    BFNY PERFORMANCE
    RIP My Friend
    cleary524's Avatar
    cleary524 is online now Hemi Reg#1120
    Nov 2008
    Northwest, RI
    There's a 3/8" drive square hole on the face of the tensioner. Insert a 3/8" breaker bar or even a rachet into it and turn in the appropriate direction to lessen the tension on the belt and then slide the belt off. Be sure to pay close attention to how the belt is wrapped around the other pulleys. There's really only one way you can put the belt on, but I've seen some struggle with getting a belt back on.
    Ditto ^ to Hemi31
    2005 Magnum RT AWD 344AWHP/358AWTRQ
    FRI Sidewinder Cam, Johan Tune, Edelbrock Headers, JBA Hi-Flo Cats, Magnaflow Catback, 180* T-stat, aFe Stg II CAI, 85mm Throttle Body, SLP 25% UDP, Catch Can, Taylor Shortys, Freak351 Trans Box , Eibach Pro Kit Springs & R1's. Interior, Engine & "M" Emblems by Billet Tech, R/T Emblems, Magnum R/T Grille, Black Heads & Tails, Eyelids
    Super T's Avatar
    Aurora, IL
    ^ What they said. You can get the "tool" for $10, it's just flat bar stock w/ the 3/8" drive welded to the end - but if you have a breaker bar already, use that. It doesn't move much, just enough to take the tension off the belt. You obviously rotate it in the direction that moves the pulley away from the belt - if the manual says counter then I believe it, I don't remember off-hand. Whatever you do, make sure the wrench you're using is good and stuck in the hole in the tensioner, and don't put your fingers between the tensioner and the belt when there's slack, just in case the wrench loses grip and it snaps back.
    slideway's Avatar
    slideway is online now Onward, through the fog
    Jun 2007
    Union co. N.J.
    Put a long 3/8 drive rachet in it at 9:00 clock(AM or PM don't matter,lol)Pull up till 11:00 clock and pull the belt off the pulley, That's the easy part though. Puttin' it back on is the hard part!
    xk49's Avatar
    Nov 2008
    USA
    Belt's off. Boy things a hell of a lot easier when you know what to do.
    Thanks for the help!
    2005rtmag is offline 2005rtmag
    Wilmington, N.C.
    Most of us learn things by trying. Don't be afraid to do it yourself unless it is something that it's obvious that it should be left to the pros.
    I learned on the old cars that were so simple starting with my 56 Chev convertible. I rebuilt the engine in that thing when I was 19. Somehow it ran great for 7k miles until I traded it. If I had to start learning on today's cars, I don't know if i would bother. They are so hard to work on in general. But, changing belts is one of the jobs that is much easier than the old days.
