Results 1 to 4 of 4
    qwkrt57's Avatar
    qwkrt57 is offline QWKRT57
    Mar 2009
    central Illinois
    Battery Reconnect Procedure
    I am going to be upgrading my radio in my 07 Magnum. Can any one please explain how to do the Battery Reconnect Procedure.
    Thanks
    2007 Magnum R/T AWD, Inferno Red
    goldsmi is offline RIFed Xeroid
    Sep 2007
    Rochester, NY
    STANDARD PROCEDURE
    BATTERY RECONNECTION
    NOTE: This reconnection procedure is to be performed anytime the battery has been disconnected.
    8F - 4 BATTERY SYSTEM LX
    1. Connect the battery negative cable (2) to the battery
    post and tighten the clamp nut.
    2. Install the rear compartment floor trim panel.
    CAUTION: Once the battery has been connected,
    review and perform the following information as
    applicable.
    AUTO UP FRONT WINDOW
    If the vehicle is equipped with the auto-up front window feature, once the battery is reconnected the door module
    needs to be calibrated. The door module requires calibration anytime the battery or door module has been disconnected
    for any length of time. To calibrate, perform the following:
    1. Turn the Ignition to the Run position.
    2. Regardless of current window position, move the driver side front window upward until the window stalls in the
    full up position. Allow the window motor to stall for at least 2 seconds before releasing the switch.
    3. Move the driver side front window downward until the window stalls in the full down position. Allow the window
    4. Move the driver side front window upward until the window stalls in the full up position. Allow the window motor
    to stall for at least 2 second before releasing the switch.
    5. Repeat steps 2, 3 and 4 for the passenger side front window.
    6. Verify the windows are properly calibrated by operating the express down and up features on the windows.
    Repeat this procedure if the calibration failed. If unable to properly calibrate after the second attempt, check the
    Driver’s Door Module (DDM) and Passenger’s Door Module (PDM) for Diagnostic Trouble Codes (DTCs) and
    correct as required.
    ELECTRONIC STABILITY PROGRAM (ESP)
    If the vehicle is equipped with ESP, once the battery is reconnected, the Steering Angle Sensor (SAS) needs to be
    calibrated. The SAS requires calibration anytime the battery or an ABS (ESP) component has been disconnected for
    any length of time. If the SAS is not calibrated following battery reconnection, the ESP/BAS indicator lamp is
    illuminated following 5 ignition cycles indicating the need for calibration.
    1. Start the engine.
    2. Center the steering wheel.
    3. Turn the steering wheel all the way to the left until the internal stop in the steering gear is met, then turn the
    wheel all the way to the right until the opposite internal stop in the steering gear is met.
    4. Center the steering wheel.
    5. Stop the engine.
    Thread titles that contain 'OMG' or 'WTF' are not read.
    The word is spelled 'Definitely'.
    There is a Y and an O in the word 'you'. 2 is not a word.
    Learn how to use 'to', 'too', and 'two'. Learn how to use 'there', 'their', and 'they're'.
    The things that stop your car are 'brakes'.
    Tires are mounted on wheels, A toilet bowl has a rim.
    It's only 'old school' if you are 12 years old - in which case it is past your bed time.
    You are probably not the first person to ever have that problem - use the Search function, then use it again.
    I don't care what you think of my car, I like it just fine.
    qwkrt57's Avatar
    Mar 2009
    central Illinois
    thanks for your help!
    qwkrt57's Avatar
    Mar 2009
    central Illinois
    changed the radio yesterday. thanks to the forum members it went great!
    Quote Originally Posted by goldsmi View Post
    STANDARD PROCEDURE
    applicable.
    5. Stop the engine.
