Can someone tell me which wire in the overhead console is the correct hot wire? I am trying to hook up a monitor and place it inside my overhead console. There are two sets of wire harness. One connects to the garage door buttons or what ever you would use them for. It has four or five wires. The other is three wires that control the overhead map lights. It has three wires. I tried the center wire (Looks yellow) but when I hook up to it the monitor blinks off and on rapidly. If I push on one of the map lights the monitor stays on like it should. I don't think I have the correct wire. I am not getting anything from the other yellow and white wire. There is also a black and green striped wire. I used the screw in the console to make the ground. Can someone help put me in the right direction? Thanks!!!![]()
300 (SRT) front, MSRT rear bumper, shaved rear wiper, 402 rear spoiler, RK/Sport raised hood, Grip grille, Boss 304 18" wheels, 245/55 BF Goodrich tires, painted coolant tank (402), painted engine cover and ABS cover, LED tail lights and side markers, LED lighting in engine bay, MagnaFlow High Flow Cats & exhaust, Vortech V-3 S/C, Vortech Predator tuned, 180 Tstat, X-treme Duty Radiator, Billet/Tech engine dress up, B/T oil catch can, Painted radiator cover! A big Thanks to Rod Burton who did the conversion & S/C install.
