I got my Magnum back from the dealership today. I'm happy with what was done. I mentioned that the rear windows sometimes wouldn't roll down unless I gently struck the inside door handle with my fist. Since they were working fine at that moment I just wanted it documented for when my warranty expires and they suddenly stop working for good. Instead of the documentation they replaced the window regulaters.![]()
The part I'm having trouble with is one they had to order. They called it "PLUG DOOR" 1AE55BD1-AA and they only ordered one of them. What is this part and why would they only need one for two rear doors? Maybe it was broken or something?
The other items I had them check and get new parts for:
Radio/A/C Bezel UZ86DX9-AA. One of the 4 screws that holds the A/C controls in broke off inside the threaded hole. I think they over tightened it the last time they replaced the bezel.
Loose rocker panel (seal cladding). They installed some new plastic pop rivets. Not sure it's any tighter but at least they did something. The panels had been slightly damaged by previous owner/driver. I ask them to check for a TSB on loose panels but apparently they didn't find anything.
The kick panel cowl on the right side is damaged and missing an alignment pin. They must have damaged this when they replaced the dash (I had the dash bubble). I had never touched this part and found it cracked and not fitting properly. They ordered new part. UM54BD1-AC.
And finally the tail gate hatch won't go up by itself. The hatch struts are weak. Ordered new parts. 5065600-AD.
