Results 1 to 6 of 6
    hemibeesteve is offline LX Padiwan
    New York
    Anyone heard of these?
    I came across a fellow srt8 owner who was having the pulsating excelleration problem and bascially his car was kind of sluggish from a dead stop. He has some mods such as Exhuast B&g stage II the basic stuff. Then he mentioned one mod called a Hyper ground wiring systems. which he explained was basically just 6 very thick cooper wires wrapped in a heat resistant rubber i believe he said. Anyway what it does is ground the electrical system like 10 times better then what we have right know which elminates noise the PCM picks up while trying to run the motor at peak performance. I may note be explaining this 100% accurate but its pretty close. If you google hyper ground wiring systems it will come up and you can read about it. it actually makes alot of sense the way they explain it on the sites . Anyway just wanting to know if anyone else is using this or knows about it
    New York
    Just one thing i forgot to mention he did the wiring to fix his problems with the excelleration and poor throttle response and he loves the results
    bigkevin20's Avatar
    bigkevin20 is offline I like them natural and heavy!!!
    Oct 2004
    PA
    placebo...
    Just looks like fancy ground wires to me. Some good audio power wire would probably do the same.
    HEMI!, Diablo Predator CAI tune SOLD, "GIGANTICAI" CAI, Blastin Bobs 7db , 22" 4inch LIP Velocity VW700 Rims on 265/35s SOLD, Chrome Grill, mirrors, pillars, handles and bumper inserts. Clear LED tails, 15" RE SX Sub, 7" Touch screen Navi, Ipod Control, TV Tuner, LED floor lights and license plate light strip, Reverse Camera,. FTP
    The "Giganticai"http://www.lxforums.com/board/f74/check-out-my-new-gigantic-diy-cai-112170/
    The Mag http://www.lxforums.com/board/f74/hear-my-baby-first-time-pics-75308/
    New York
    You know what that was the first thing i thought of two but then i got to thinkin now this may be a bad comparison but when i by wires for my big screen I always buy the wires that cost way more money and for a good reason because the wires may do the same thing but one set does it extremely better as far as picture quality so i think the same may be here you could use some good audio cable but it probably would not compare. anyway thanks for the input I think I'm gonna try it because during my research of the product the description of what it does just makes sense.
    LUVMYRT's Avatar
    LUVMYRT is offline I love the sound of scream in the porn!!
    Aug 2007
    Union City,CA
    Hyper Ground System
    The new Hyper Ground System is the safe and reliable generation tuning system that provides a low resistance ground path. A better ground gives more torque, better mileage, better response, and better starting ability.
    This system provides direct ground path from battery negative to body, chassis, and engine components to give extreme improvement on electrical circulation. In addition Hyper Ground System cables have 10 times less impedance than factory ground systems which provides immaculate conduction to prevent electrical power loss.The higher resistance of factory grounds, effect the ignition system and obstructs the primary potential.
    The Hyper Ground System uses thick gauge 99.99% pure copper, and connects directly from the cylinder head and other points under the hood to the battery, to provide an ultra low resistance connection.This will increase the primary potential of regular cars to ignition tuned vehicles.
    Comparison of Voltage Resistance
    This oscilograph proves how voltage drops with the Hyper Ground System at the cranking.
    (Smaller waves and lower trace on the graph means less resistance)
    Design of Hyper Ground System
    4-layered construction
    1. Outer Tubing
      Consists of exclusive material that provides superior heat resistance and flexibility.
    2. Shield Mesh
      Provides additional strength and attractive looks in the engine compartment.
    3. Inner Tube
      Reduces noise and provides additional strength, also to protect sliding of Shield Mesh and Outer Tubing (Only installed in Gold and Silver Cables)
    4. Ultra Low Impedance Copper Wiring
      Uses unique design of 99.99% copper core to get the lowest impedance. Copper core surface is protected against corrosion.
    Gain Torque and Horsepower (HONDA INTEGRA TYPE-R) Increased Fuel Mileage
    A litle to tech for me but there it is
    "With a turbo, exhaust gasses go into the turbocharger and spin it, with a supercharger, air goes in, witchcraft happens and you go faster."
    - Jeremy Clarkson
    desquirrel is online now LX Padiwan
    Jan 2005
    Rahway, NJ
    BS
    And in "tv wires", if you're referring to HDMI, HDMI is twisted pair using a digital signal. The difference in performance between the $6 cable and the $100 cable is zero.
