Results 1 to 14 of 14
Thread: Antifreeze
    cliff_ford is offline Usque ad mortem bibendum
    Dec 2006
    Antifreeze
    Bought some Mopar 5 year/150,000 mile antifreeze from a Dodge dealer here in England. It is yellow, will it mix ok with the red/orange factory fitted stuff?
    Dealer said it will.......I'm not so sure....Dex-cool type problems spring to mind.
    Thanks.
    hondaman9468's Avatar
    hondaman9468 is online now 05 r/t cool van.
    woodstock, GA
    yes it will with no problem, the yellow should be globe antifreeze....( mixes with any)
    jiffy lube added green antifreeze to the orange on a friends monte carlo and it turned into a brown paste. the car would over heat because it was too thick to flow through the radiator.
    why not just get the mopar orange antifreeze?
    Dec 2006
    Quote Originally Posted by 65standard View Post
    Your friend's problem was what I was worried about.
    Hondaman9468 has set my mind at rest.
    The orange stuff is not sold by the Dodge dealers over here. I expect it can be obtained with enough effort.
    Thanks guys.
    FloridaRT's Avatar
    FloridaRT is online now LX Oldtimer
    Ocala, Florida :-)
    You can't put English anti-freeze in an American car...................LOL
    Just kidding.
    Bob
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by FloridaRT View Post
    Just kidding.
    Bob
    are you saying the exhaust might pick up a bit of an accent?
    Ghostface Mag's Avatar
    Ghostface Mag is offline Vendor/Shop Car for HHP Racing...
    Jun 2005
    "Somewhere in MD. so you can HATE on me"...
    Quote Originally Posted by 06SilverSteel View Post
    Good one....Attachment 7954Attachment 7954
    Check Us Out Online & Contact Us @ 1-888-894-1115
    HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryO² Paramount NAG1
    Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
    ZMagnum's Avatar
    Tucson, AZ
    Just today I purchaed Mopar antifreeze/coolant. It's 5 year/100,000 mile. AFAIK it's an exact match to the pink stuff they put it at the factory. Part number 05066386AA.
    If you are concerned, exchange yours for this stuff.
    moparman53's Avatar
    moparman53 is offline Finally got a HEMI again.
    Nov 2004
    E Williamson Co, Central Texas
    I know stock Mopar antifreeze for our cars is "embittered", but I don't think it wouldn't work without it. Personally, I use it.
    ZMagnum's Avatar
    Tucson, AZ
    Yeah, that's what mine says on the container. It's embittered so that cats don't drink it an die.
    MagNite is offline LX Guru
    Rochester,N.Y.
    You can't mix an Ethylene Glycol (non-organic) with an organic such as Dex cool. The two aren't compatible. What morons at Jiffy Lube
    desquirrel is offline LX Padiwan
    Jan 2005
    Rahway, NJ
    Ethylene glycol is organic.
    Rochester,N.Y.
    You're right. I guess I thought different because I've heard the new types described as "organic" antifreeze while I never heard the old (green) type referred to as such. Actually the difference is Ethylene glycol (green) and Propylene glycol, the latter is suppossed to be much less toxic. You still can't mix the old and new or even the new and new for that matter unless approved. Don't know why the heck there has to be so many different ones out there. Pink, Orange, Yellow, etc. .... What happened to the good old days when it was all Green and you could mix any brand together? That's progress I guess.
    Jan 2005
    Rahway, NJ
    Practically everything uses ethylene glycol. The newer products designed for aluminum cooling passages use organic acids to prevent corrosion. If these were added to conventional solutions which have high concentrations of phosphates and mineral compounds, you get chemical reactions which precipitate out the minerals and salts. It is also a good idea to use demineralized water when topping up and making up the volume on inital installations/changes.
