Results 1 to 15 of 18
    YOUNG_G is offline LX Newbie
    Feb 2006
    91 OCTAIN Premium FUEL for HEMI"S
    I have always used Premium for my 5.7L Hemi on my 300c, is it necessary because I have read on other forums that you should not cuz the block may crack ect.......
    What do all you HEMI owners use.....
    YF-AKA the BANK --06 300C AWD-
    GRILLIN' THE GAME WITH DIAMONDS ON MY CHAIN!
    MODS:
    DUB Edt. Mopar Grill- Bentley Steeze
    Hoen Bulb Upgrade- Hi/Lo/Fogs
    Xenon Led Interior & License Plate lights
    Hardwired Radar- wire runs from center speaker
    PA w/ 60 SFX horn, speaker mounted behind the Grill
    Future Mods:
    22" Chrome Rims
    Tint
    Various Body Styling Mods- ie spoiler, bodykit...ect
    sidetrack is offline ~~~~~~~~~
    Quote Originally Posted by YOUNG_G
    Chrysler owners manual specifically says not to use 91.
    Where do you read that 91 octane will crack the block?
    The reason I am curious is that the Superchips Flashpaq 91 tune requires 91 octane. I have been curious how Flashpaq negates the long-term negative implications, if any, of running 91 octane.
    Jweezy's Avatar
    Jweezy is offline J to da Weezy..Baby!!
    May 2006
    Virginia
    i use 93 in my Charger, because i get better gas milage with it...
    jweezy
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    Daniel454's Avatar
    Daniel454 is offline MAG V
    Nov 2005
    Union Grove, AL
    My .02 Cents...
    Using higher than needed octane fuel will not crack the block. It can however, cause excessive emissions resulting in a clogged catalytic converter. I say this lightly, as this is possible but not likely.
    Truth is, with computer controlled cars, your timing is set based on the programming, which is preset based on the expected fuel. Using higher than needed octane will result in no power improvements, nothing at all. The result MAY be that the car will run slightly better but it is not a direct result of the higher octane, but rather, the addition of detergents or just in general BETTER gas. But the octane itself will not make any difference and will not help or hurt performance.
    SUPERCHIPS, among other things, advances the timing, meaning now the car is EXPECTING the higher octane fuel. The timing will be as such that emissions are no higher (in a perfect world) than before, just that the car can now take advantage of the higher octane. Using superchips to advance the timing, but continuing to use lower octane, will result likely in pinging or other issues, in which the car will then retard timing, in the end producing even less power than before, and possibly damaging other systems.
    OK, long story short. Summary.
    Factory the car is set to run on mid grade, using higher does not help performance but may help because you end up using a better fuel, but in the long term it MAY result in emissions (CAT, O2 sensors, etc) issues... Using Lower (Low grade) fuel can result in pinging or knocking, and will further reduce power.
    Superchips performance tune now sets the car to expect premium, likewise as before, using higher or lower octane will result in un-desired reults.
    Bottom line, use good quality with octane matched to the programming of the car (Stock = mid grade, superchips = Premium).
    2005 Dodge Magnum AWD R/T (MINE) - MySpace Profile
    2006 Chrysler 300C SRT8 (Wife's)
    Super T's Avatar
    Aurora, IL
    ^ amen
    Feb 2006
    Read this: Stage Two JET Chip questions
    Thats where i got it from....
    MODS:
    Future Mods:
    22" Chrome Rims
    Tint
    done's Avatar
    done is online now Member for 7 years
    Old Hickory, TN
    maybe he was thinking about smoking crack?
    Big Boy's Avatar
    Big Boy is online now 2013 or Bust .....
    Feb 2006
    Columbia Ridge, OR
    It's very hard for me to believe, anyone on this forum actually believes what salesmen say.
    Some were selling other brands of cars or washing machines the week before.
    It looks like 2012 will be very good indeed.
    Unless the Mayans are right, then, well, never mind.
    Shakin's Avatar
    Shakin is offline The member formerly known as Jleilich
    May 2006
    Overlea/Fullerton, Md
    higher octane cracking the block..? thats a new one.
    06 Charger R/T Black
    Full JBA Headers, Mids, Catback, 35% tint, honeycomb grille, chinspoiler, and rear diffuser, SC Tuner. Danko Reproductions shaker hood(Mopower)
    70 Plymouth Cuda 440
    05 Ducati Monster S4R
    87 Dakota beater truck
    MomsR/T's Avatar
    Houston
    Daniel454's Avatar
    Nov 2005
    Union Grove, AL
    Quote Originally Posted by MomsR/T
    are you positive higher octane = higher emissions?
    It isnt an exact equal...
    You have the possibility that without the advanced timing to accomodate the higher octane, that you will have more unburned fuel, or in other words, it is possible to run richer... Now with that being said, I have seen and heard of many people running higher octane without running into emissions issues or clogged cats... Also since we have the trailing spark plug, the scenario is even less likely, but it is still possible...
    For me, if I get no performance gain, then why spend the extra money.... Once superchips, or in other words, a timing advance was available, I was one of the first to jump on it and start taking advantage of premium fuel.
    MomsR/T's Avatar
    Houston
    i wasn't looking as to WHY someone would run 91-93 with no advantage, however I was taught that the higher octanes actually burned more completely.
    I would assume that a more complete burn lead to lower emissions........
    Just wondering
    aries4life's Avatar
    aries4life is offline Goodbye Mag
    Jan 2006
    Georgia
    Higher octane fuel is less likely to preignite from compression - no? Does higher octane burn at a higher temp?
    I, too, believe that salesman is abusing a controlled substance.
    '05 Mag R/T - Shaved Ram logo and bumper indentions - Eibach ProKit - JBA Shorty Headers - JBA mids - SRT-8 X-over - Magnaflow muffs - Borla pipes - Zoomers tips - DiabloSport Predator - 170 deg thermostat - Jim Turner Fan Mod - Modded SRT Airbox - Quickest Superstock 5.7L at S.E. Shindig '08 You will be missed... R.I.P. :(
    Daniel454's Avatar
    Nov 2005
    Union Grove, AL
    Just wondering
    hmmm, not sure... I am thinking higher octanes do burn more completely, but only when timing is such that can take advantage of it... Like I said before, just my .02 cents... but I think we can all agree any salesman that passes along information about higher octane fuel cracking a block should be avoided at all cost.
