Results 1 to 15 of 17
    sticknanko's Avatar
    sticknanko is offline LX Newbie
    Jun 2006
    Stafford Va
    70 mph vibration?
    I have a 06 charger srt8. and as soon as i hit 70 i get a bad vibration in my sterring wheel. i just got the tires balanced and that did not fix anything. any one know what the problem could be. and ps. my brake sqeek real bad. but the pads dont need changed. anything i can do to stop that?
    josh05magnum's Avatar
    josh05magnum is offline Need. More. Mods.
    Plainfield, IL
    Bump for same problem-
    I have an 05 Magnum RT, same problem, between around 70 and 80 steering wheel vibrates/shakes bad. I am pretty sure my rotors are warped a bit, as braking causes a shake as well, but the problem Sticknanko describes, happens to me also with NO braking.
    I also had my wheels balanced as I thought that was the issue (actually had them balanced twice, but thats another story)
    2005 MAGNUM RT
    AIRHAMMER, Predator, 180 Tstat, Flowmaster 44's w/ Zoomers Cannon Tips, Blue LED Interior Lighting, 06 Radio with Aux Input
    MooNDoGGie's Avatar
    MooNDoGGie is offline Absent From Malaise
    Cambridge, Ontario
    Nope your wheels are not balanced properly. Take them back. It don't take much to get a slight shimmy. I just replaced my 20's and i'm getting it also. My car is going back for tire balance again.
    ____°şİMo0NDoGGieİş°
    PERFORMANCE MODs: kw coilovers,zoomers exhaust,jba shortie headers,diablo predator,hammer h.o.CAI,power slot rotors,hawk pads
    COSMETIC MODS: 20" zinik's,msrt8 front fascia,colour matched fog light bezels & rear wing,shaved front badge,6000k HID headlights & foglights,shaved & debadged,tinted FOG tail lights
    INTERIOR MODS: nav radio,msrt8 kicker sub-woofer,T-handle shifter knob & leather boot,BT aluminum dash knobs
    FloridaRT's Avatar
    Ocala, Florida :-)
    Rotate the tires and see if the problem goes away.
    Bob
    Plainfield, IL
    I had mine Balanced a 2nd time at a different Discount Tire after the first time didn't fix it.
    Still have the vibration/shake right at the same speeds.
    Any other ideas? I can try and have the tires rotated again, but then I won't be getting even tire wear.. (for some odd reason my back tires wear out quicker than the fronts on RWD cars)
    2005 MAGNUM RT
    rickf28's Avatar
    rickf28 is offline I wanna go faster!!
    Nov 2007
    Sumter, SC/ currently Iraq
    My car is rear wheel, and the back wears out very quick due to my heavy take off foot...My car starts to shake at 60 to 80mph when my rear tires are wearing out (from spinning)...ususally when this happens its time to order new rear tires...
    I have read lots of posts about our cars being hard to balance, Ive never had trouble yet but others have...I never gave it much thought but all the tire spinning i do I figure the tire wears uneven or I sling wieghts but like I said earlier...mine starts to vibrate after tires are wore out from spinning...Rick
    My Name is Rick
    Cars Name is Alice
    SEE SIG ABOVE plus....Lots of BT goodies inside - Lots of custom aluminum inside, Factory REC Nav
    AAC HID fog lights - LED smoked tail lights...with LED bulbs - LED everywhere inside and out
    More to come, Im a broke A$$
    Plainfield, IL
    Hmmm, mine was just rotated and balanced though. And all tires deffinitly have a decent amount of tread left, just two have less than the other two.
    It's driving me nuts though, makes the car ride like a POS at highway speeds when the steering wheel shakes.
    Other than rims and tires, is there anything else that could do this? Could warped rotors be warped enough to cause something like this at certain speeds?
    2005 MAGNUM RT
    JCat's Avatar
    JCat is offline Not my only vehicle !
    Nov 2006
    Shake at 70ish has been a problem I have seen many threads about. It requires a top-notch shop to root out the problem. It could be many, many different things that could cause it. I have even heard solutions that included: balance, new tires, steering box and linkage, aftermarket wheels with very slightly different bolt pattern, and LOTS of trial and error.
    If your brakes squeal, my recommendation is to try a different brake pad. Hawks are good.
    wantit is offline LX Newbie
    Oct 2005
    Long Island, New York
    I had the same problem with my 300 srt, had the wheels balanced twice and still had the problem. than I had the wheels " road force balanced" and that solved the problem. call some tire shops, and ask if they have the Hunter 9700 road force machine, first they break the bead, and rotate the tire to a different position on the wheel if necessary, than balance it.
    as close to perfect as you can get. they charged me $30 per wheel, worth every penny.
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    Have someone check tie rid ends. There are many threads about premature tie rod wear. Slack in tie rods will cause a shimmy in the stearing.
    magnum lover's Avatar
    magnum lover is offline Crew Chief for #4 SPO
    Jun 2005
    Conklin, NY
    What are your lugs torqued to?
    05 Magnum Mineral Grey R/T Hemi Reg# 00310
    http://community.webshots.com/user/magnumlover
    albums with headlight/taillight/bezels & interior changes
    shade's Avatar
    shade is offline LX Newbie
    Jan 2006
    Your tires need to be road force balanced. Most tire shops use a lower end machine that simulates a road force balance.
    They said everything was spot on. Took it out for a spin and a nasty vibration.
    Took it to the dealer where they have the high end machine and said the tires were not even close to balanced.
    After they got done it was smooth as glass to 140
    06 300SRT8
    Silver Steel
    Options: Stripped
    Plainfield, IL
    Hmmm, I may have the dealer check the wheels when it's in for the A/C issue and rear window issue...
    Gonna suck if I can't take it to Discount Tire to get stuff balanced anymore. It's convenient.....
    2005 MAGNUM RT
    mindspin's Avatar
    mindspin is offline LX Newbie
    Massachusetts
    Same issue
    I had the same issue up until last friday.... Vibration at 80, scheduled an appointment for that and oil change. The dealer road force balanced the tires and now she is smooth as can be. I think road force is the way to go.
    Current/Future Mods
    <X>AFE Stage 2
    <X>Predator Tuner
    <X>20% Tint
    <X>180 Thermostat
    <X>Stealth Auto Turn Signals
    <X>Red/Smoked LED tail lights
    <X>6000k hid fog-lights
    <X>Super White LED Interior Bulbs
    < >Grip Tuning Grill (Still no way to mount my front plate!!)
    <X>Clear Corners
    Plainfield, IL
    Can anyone explain the difference between a "Road Force" balance, and whatever Discount Tire does?
    I am curious at this point.
    2005 MAGNUM RT
