    thewagon's Avatar
    thewagon is offline Hurry up and get here Summer!
    Jun 2005
    Sparks, NV
    300 steering wheel to Magnum question
    Will a 300c steering wheel work as a direct replacement with the Magnum steering wheel?
    Meaning, the wood top 300 replace the leather wheel in the magnum?
    Will lack of or not steering wheel controls be fine? Are they molded the same way?
    And is this a DIY job?
    Thanks,
    Andrew
    2005 Inferno Red Magnum R/T & 2010 RAM 1500 4x4 Hemi
    Retired USAF/USANG 22yrs, Det 2 23ADS, 274th CCSQ, 213th EIS
    Robins_SXT's Avatar
    Robins_SXT is offline LX Padiwan
    Nov 2004
    Warner Robins, GA
    Quote Originally Posted by thewagon View Post
    Thanks,
    Andrew
    Wheels are directly interchangeable. If you have the steering wheel controls they'll swap right over with the wiring harness. The switches just snap into the wheel.
    It's DIY IMO. You'll need a hex drive socket for your torque wrench. The bolt holding the wheel on has a hex recess & a purty sporty torque.
    Disconnect the battery and let it sit the prescribed time before fritzing with the airbag. You'd not like the airbag going off in your face.
    If you're looking at the wheel motorcitycam has for sale on ebay I'd stay away from that. I've observed ebay rule violations on his part and reported him twice.
    thewagon's Avatar
    Jun 2005
    Sparks, NV
    thanks Robin. Its from a local member, erna. Local Dodge Shop quoted $85 if no problems and obviously no warranty.
