    BostonSXT is offline LX Newbie
    May 2005
    Mass
    3 Questions please (troubleshooting)
    Hey there.
    Sometimes the BAS light comes on when I start the car and stays on. If I re-start it goes out. Any thoughts?
    Sometimes the car just cranks and doesnt want to start unless I let the key cycle for a few seconds. Any thoughts
    I was told that the rack needs to be replaced because an inner tie rod is bad. Is this true.
    Any input on these thre things would be greatly appreciated.
    Thanks.
    fnkychkn's Avatar
    greasy cardboard box
    1- the BAS/ESP warning lamp will illuminate whenever the ABM (antilock brake module) detects a malfunction. the most common cause is steering angle sensor communication. when this occurs, even for just a few seconds, the ABM will request warning lamp illumination for the entire drive cycle.
    2- would need some personal time with your car to diagnose. too many possibilities. perhaps a fuel pressure problem.
    3- the inner tie rod ends are serviced as part of the steering rack.
    May 2005
    Mass
    Thank you!
